Point to point or pcb? - Page 12 - diyAudio
Old 15th December 2012, 08:18 PM   #111
roline is offline roline  United States
roline's Avatar
The precurser to SMD PCB's was the ceramic hybrid field that was very strong in the 70's. We would silkscreen .005" traced and spaces with gold ink, mount IC's , transistors as cut from the wafers and wire bond with gold wire. The resistors were thick film Ruthenium oxide laser cut to 1%, ceramic or tantalum capacitors could be soldered/ epoxied to the substrate. The most complex was a 6 metal layer, 19 IC die 256 wire bond hybrid that we did for HP. Approx 1"x3" in size. Raytheon was doing pacemakers with this technology.
The fastest circuit that we did slewed at 6,000V/u second.... We also did RF and IF circuits used in handheld radios, DTMF filters and other custom AF circuits... I did a power op-amp design but power density was a limitation of getting the heat out. I could only get 60watts out of it.
SO many tubes, SO little time!!!
Old 16th December 2012, 09:54 AM   #112
marce is offline marce  United Kingdom
They are still being done today, though instead of a ceramic inteposer standard PCB materials are used (though usually a higer Tg grade), BGA's etc.
QPI-21LZ
One example with bottom terminations, others use gold plated semicircle s on the outer edges.
We did a coule of modules back in the days, the biggest problem was the difference in thermal expansion between FR4 and the ceramic, not so bad when they had through hole legs on a 0.1mm pitch, but became problematic as SMD apeared and sizes reduced.
They looked cool though especially if you had them hermeticaly sealed and gold flashed legs...
Just for the record, my favorite amps are my class A EL84 monoblocks in triode mode, so while I do favour PCBs I have a point to point amps, it will be these that one day I shall make machined copper interconnects and put in a clear polycarbonate case...one day.
Point 2 Point (no PCB) for TDA7293, TDA7294, TDA7295, TDA7296. danielwritesbac Chip Amps 152 28th January 2016 07:17 AM
LM3386: point to point or PCB? tbj Chip Amps 21 6th November 2012 01:21 PM
F5 Point to Point Power Supply Schematic bassnkeys Pass Labs 15 22nd February 2012 04:32 AM
Anyone use magnet wire for point to point wiring projects? Hybrid fourdoor Parts 10 2nd February 2004 08:11 AM
Point to point or use a PCB jarthel Tubes / Valves 13 10th June 2003 09:15 PM
Copyright 1999-2017 diyAudio
