OPT power rating and amplifier power - diyAudio
Old 6th December 2012, 01:21 AM   #1
MGH is offline MGH  United States
Default OPT power rating and amplifier power
Can someone explain the relationship between the two? Specifically is it better to use an OPT whose wattage rating is greater than the output power of the amplifier? What would happen if you use an OPT rated at 120 watts in an amplifier rated at 200 watts?
Old 6th December 2012, 01:42 AM   #2
expert in tautology
bear's Avatar
You'd get core saturation and so distortion, more obviously at low frequencies in typical listening use.
Best to have a bigger OPT than not, especially if LF is important.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 6th December 2012, 06:03 AM   #3
TonyTecson's Avatar
here you go....output-trans-theory
unlike SS amps, power rating in a tube amp is never constant across the audio band....
it is lower at either side of the 20hz-20khz audio band....
most tube power ratings are quoted at 1khz...so that a 120 watt rated traffo at 30 to 16khz can be a 60 watt traffo at 20hz to 20khz
then there is also the 1watt power frequency response, it is much wider at that power level....
a blast from the past, Dynaco irons.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 6th December 2012, 07:36 PM   #4
Thanks Tony. That's kinda depressing. Undistorted power drops to half at the frequency extremes.
Old 6th December 2012, 09:19 PM   #5
TonyTecson's Avatar
we have to live with the reality of things.....but then again, OPT's can be designed to any spec if one wishes, those are Dynaco offerings and considered as very good at the time....Patrick Turner has an excellent exposition re OPT's in his website, read it carefully and you will understand why...
Old 7th December 2012, 08:51 AM   #6
TonyTecson's Avatar
reason is that the OPT primary inductance drops as frequency decreases...OPT design is more of an art than science...a compromise as characteristics are working against each other.....Norman Crowhurst has written many fine articles about OPT's....
Speaker power rating vs amplifier rating Fusion916 Solid State 8 10th March 2012 09:33 AM
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
ideal amplifier power rating to match speakers dicksolder Solid State 1 19th March 2010 05:01 PM
What should be the transformer rating in respect to wattage of a power amplifier, rajeev luthra Solid State 38 31st July 2004 05:45 AM
amplifier power rating for Proac 2.5 clone supernet Multi-Way 1 24th November 2002 06:54 PM
Copyright 1999-2017 diyAudio
