6BG6-GA - diyAudio
Old 6th December 2012, 12:30 AM   #1
Default 6BG6-GA
Any practical experience running the "standard" 6BG6-GA at 450V in triode or ultralinear for SE operation at 5K?
Looks to be about -22.5V cathode bias at 40mA.
Looks OK to me. Just looking for someone who has done this.
Thanks,
Scott
Old 6th December 2012, 07:41 AM   #2
coresta is offline coresta  France
coresta's Avatar
too high ! look at the 807 data sheet !
Old 6th December 2012, 08:01 AM   #3
I did look at the Brimar 807 data sheet. It shows 600V max for the anode. The 6BG6-GA shows 700V max. The plate voltage in my scenario would be about 425V. Although the screen is shown as 350V max for the 6GB6, there is no definitive info regarding the max voltage with the screen tied to the plate or run as ultra-linear. The reason for my question.
Thanks.
Old 6th December 2012, 08:15 AM   #4
coresta's Avatar
Yes, i know ...the 807 was never intended to go ultralinear ... i' d avoid... go 450Va and regulated 300Vg2
Old 6th December 2012, 08:22 AM   #5
Sounds good, I think I'll try it your way first.
So the 40mA and -22.5V looks OK with a 5K OT?
Thanks very much.
Scott
Old 6th December 2012, 08:30 AM   #6
coresta's Avatar
yep !
Old 6th December 2012, 08:33 AM   #7
Thank you very much for your reply. I appreciate it.
Old 8th December 2012, 01:33 AM   #8
I looked at my stash of 6BG6-GA. It appears as though the ones I have are the large plates. The only thing is they have the side getters. But other than that, they have the large gray plates as shown in the attachment.
Has anyone else come across this?
ImageShack® - Online Photo and Video Hosting
Old 8th December 2012, 06:55 AM   #9
coresta's Avatar
Yes, the grey one is "modern" , beefier, than the "old" black genuine ! no problem, these will last a lot more than the chinese 6L6-KT66-6550-KT88 sold nowadays ....
Old 8th December 2012, 08:18 PM   #10
Miles Prower's Avatar
This involves spec busting so far as the screen voltage rating. It's getting into iffy territory: maybe it works, since the screen and plate are always at the same voltage, and you have more leeway. Then, perhaps, it doesn't, or it could be very dependent on manufacturer types.
I've used these 6L6-oids, but only as pents, and also including parallel local NFB. Used that way, they sound just great.
There are no foxes in atheistholes
www.dolphin-hsl.com
6BG6 for KT66 exurbia Tubes / Valves 4 23rd November 2008 02:09 PM
Super 6BG6 vs. 6550 wrenchone Tubes / Valves 13 3rd September 2008 06:36 AM
6BG6 = 6L6GC with top cap - cheap! ray_moth Tubes / Valves 6 31st May 2007 05:46 PM
Has anybody built 6BG6 or similar OTL amp? rnx69 Tubes / Valves 2 14th April 2004 01:25 PM
Gas-coupled 6L6/6BG6-G SE Joel Tubes / Valves 11 16th February 2003 10:08 PM
Copyright 1999-2017 diyAudio
