Old 6th January 2013, 04:43 AM   #21
scott17 is offline scott17  United States
scott17's Avatar
Originally Posted by scott17 View Post
Does anyone know if the large grey plate 6BG6GA were ever made with side getters?
I guess they did make the large plate with side getters. I've been running mine at 430V, 30W, in UL mode, no red plating.
Old 11th January 2013, 08:18 PM   #22
scott17's Avatar
I purchased a few of the "super" 6BG6GA. Here is a photo of the "super" version (on the left) next to the version I have. The plates look identical. Can someone tell me what the 2 fins on top of the mica insulator are for?
I am now running my version in SE UL mode at 465V on the plate, 455V on the screen, at 73.4mA. About 30W dissipation. So far, so good.
Old 11th January 2013, 10:12 PM   #23
vinylkid58's Avatar
Possibly to radiate heat away from the grid posts?
What sort of a driver config. are you using for this project? Thx.
jeff
Old 12th January 2013, 02:26 AM   #24
Miles Prower's Avatar
They look like screen grid radiators.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 12th January 2013, 03:11 AM   #25
scott17's Avatar
A 6SN7 with 355V through a 28K plate resistor. A green and white LED in series on the cathode at 5.25V for 6.3mA current. I will post a schematic when I get to work in the morning.
jeff
Old 12th January 2013, 03:14 AM   #26
scott17's Avatar
I looked that up. That looks exactly like what they are. Thanks.
Old 13th January 2013, 12:00 AM   #27
scott17's Avatar
Default 6BG6GA SE UL
Very simplistic circuit.
I had a PT with a 12.6 CT & 10V CT secondaries, so I wanted to make use of it. I know the 5AR4s are overkill in this application. I will ultimately use 5V4GAs as the rectifiers, I just don't have them yet.
Output measured at about 7.5W RMS
Scott
Old 2nd March 2013, 02:21 PM   #28
prairieboy's Avatar
Scott, did you do any 'in circuit' comparisons between the 'super' 6BG6GA you purchased versus the side getter version you already had? I was checking through a box of tubes from an old Ebay purchase this morning, and found I've got 12 of the 6BG6GA that are identical to your original ones (Sylvania, grey plates, side getters, screen grid radiators) so I'm curious if you concluded that they 'are' the super 6BG6GAs?
Old 2nd March 2013, 03:56 PM   #29
scott17's Avatar
Both tubes run at the same parameters in my circuit. Comparing the plates of the two they are identical even down to the mica insulators. Only difference is apparently the side getter and screen radiators.
In case you didn't see the photo linked in post #8, you can definitely see the difference there.
Old 3rd March 2013, 02:00 AM   #30
prairieboy's Avatar
Thanks for the response, Scott.
BTW, I did see the photo in #8. The 6BG6GAs I have look like the left hand image, with the side getters.
So, from what you're saying I may infer that the top getter 'super' 6BG6GAs are functionally the same as the side getter, big, gray, plate 6BG6GAs? If so, good news.
6BG6 for KT66 exurbia Tubes / Valves 4 23rd November 2008 02:09 PM
Super 6BG6 vs. 6550 wrenchone Tubes / Valves 13 3rd September 2008 06:36 AM
6BG6 = 6L6GC with top cap - cheap! ray_moth Tubes / Valves 6 31st May 2007 05:46 PM
Has anybody built 6BG6 or similar OTL amp? rnx69 Tubes / Valves 2 14th April 2004 01:25 PM
Gas-coupled 6L6/6BG6-G SE Joel Tubes / Valves 11 16th February 2003 10:08 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
