Old 6th December 2012, 12:01 AM   #1
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
Default EL84 driving EL84 SET with fixed bias
I would like to make a(nother) low-powered EL84 amp.
Rationale:
-EL84 has just the mu we want to drive another EL84
-With the same tube, we get distortion cancellation under a specific bias and voltage setting
-It is a VERY linear tube, and distortion should be extremely low with a CCS load
-Can make a low powered speaker amp, preamp, headphone amp, or driver stage for a 300B, 845, GM70, etc.
-The GE and Sylvania EL84 sounds very similar to a 45 DHT, but has the advantages of indirect heating. The Russian and Chinese tubes won't give that DHT sound, unfortunately.
To accomplish these goals I will use a CCS loaded driver stage and fixed bias on the output EL84. One can use a 12V battery or an adjustable power supply to adjust bias current.
Old 6th December 2012, 12:06 AM   #2
jerluwoo's Avatar
5W EL84 drive EL84 SE
Old 6th December 2012, 12:33 AM   #3
Thanks for the link, but the schematics on that page are not showing up due to broken links.
Old 6th December 2012, 12:38 AM   #4
Two of my goals for this project are:
(1) to compare the typical cathode bias for EL84 versus fixed bias. I really like the idea of a 9V battery, but have never tried.
(2) to evaluate the sound quality of EL84 as driver compared to others I've used to drive EL84 in the past such as 6DJ8, 12A*7, 12BH7, 5687, etc.
Old 6th December 2012, 05:35 AM   #5
Svein_B is offline Svein_B  Norway
Have a look also at Thorsten Loesch's "Legacy" amp with SV83/EL84 pentode mode driver for 300B.
http://community.fortunecity.ws/rive...cy/Legacy.html
SB
Old 10th January 2013, 11:29 AM   #6
SB
Hi Sven
Regarding this Legacy you posted the problem is the power supply.
I'm interested to assembly a Legacy but with another Power Supply.
Do you have some hints to give me?
Jones
Old 10th January 2013, 12:43 PM   #7
I think from my tests that there are better drivers tha n the el84. I dont know if you'd get some cancelation using the same tube though?
Old 10th January 2013, 01:19 PM   #8
tinitus is offline tinitus  Europe
EL84 drive EL84 could be something you do for fun
though I guess there would be better ways to build EL84 amp
funny, but yesterday I thought about using EL84 in a QUAD II style amp using the new Amplimo trafos with cathode feedback winding
Old 16th January 2013, 06:46 AM   #9
I just drew this on a piece of paper. Can you guys look this over before I start building?
Old 16th January 2013, 07:29 AM   #10
artosalo's Avatar
Based on my tests with many triode connected pentodes with CCS loading I think that the first EL84 will work well with smaller anode current, say 10 mA.
It's linearity is improved if the grid resistor of second EL84 is increased.
The maximum recommended by Philips is 300 k.
EL84 fixed bias PP Triode DrewP Tubes / Valves 20 28th April 2013 09:56 AM
FS: EL84 EI Yugoslavia & EL84 Tungsram NOS Bulk radiostar Swap Meet 3 29th January 2012 08:46 AM
EL84 fixed fixed bias razorrick1293 Tubes / Valves 3 20th November 2011 03:33 PM
EL84 driving EL84 SEP tweakk Tubes / Valves 22 9th March 2011 11:23 AM
ppp el84 fixed bias schematics jogas Tubes / Valves 17 31st August 2009 01:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
