According to RCA datasheet it's 'permissible' to mount it horizontally providing the filament is in a horizontal plane.
Anybody actually done this - any issues ? I asked manufacturer of JJ-2A3-40 and they don't recommend it for a 2A3 or 300B from any manufacturer. The reason for asking is that horizontal mounting provides another option, some flexibility in the physical construction of a project.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#2 |
what a shame
![]() ![]() how about 45degr angling instead it would at least look more weird than stupid
#3 |
The Fi X 2A3 amplifier has them mounted sideways. I would suggest allowing for the sockets to be rotated a bit as I've not seen too many 2A3 tubes that always line up properly to the base pins as noted in the datasheet.
Personally, I still prefer them mounted vertically, but for NOS tubes, it was a supported practice. Regards, KM
... just because you're paranoid, it doesn't mean they're not after you... |
#4 |
#5 |
So for NOS, it's not an issue and I've heard no bad things about the fi.
I may ask JJ specifically about the Fi 2A3 and suitability of the JJ 2A3 40 the 45 degrees options looks cool - looks like missile launchers !
#6 |
I always thought the filament was supposed to be vertical, not horizontal.
If it's horizontal, it might sag to the bottom, and touch the grid (or change the operating parameters significantly). If it's vertical, if it sags, it won't touch any other element. |
#7 |
With indirectly heated cathods like the EL34 it doesn't much matter.
Yes, you are absolutely correct.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#8 |
Well, according to the RCA data sheet published October 15, 1947, the accepted mounting position (for the 2A3) was changed to "Any". This would also account for the slack in the alignment spec for the base pins to filament. I've noticed the same on many 45 triodes.
Regards, KM
#9 |
the RCA sheet I have was specific about orientation, but a Tung Sol data sheet said 'Any'. My conclusion is that it's safe for NOS, but there's no harm following the recommendation in the original RCA for orientation. If I remember it was to keep certain pins in a horizontal plane not the grid so it may be that it means the filament is vertical.
However, I'm interested in a modern 2A3. I can't see why these tubes would be less suitable for horizontal mounting - but I don't know and am still curious ? I notice that there are reviews on the internet for the JJ 2A3 in the Fi 2A3.
#10 |
I suspect that the later data sheet referred to the tubes using sprung filaments. I have an older 6A3, and a couple of 6B4Gs with slightly larger cross section (rectangular) filaments that are not sprung. I suspect these might be more prone to sag in some positions.
Here is what mean by sprung and unsprung. The one without the tension arms (unsprung) has a larger cross section filament. Last edited by TheGimp; 5th December 2012 at 05:54 PM. |
| Laying front speakers horizontally | 4sfed | Multi-Way | 27 | 23rd September 2011 06:13 PM |
| Can the 6S33S/6C33C be mounted horizontally? | ben_f_m | Tubes / Valves | 7 | 10th August 2010 06:16 PM |
| WTB: OPTs for 2A3 or 45 SE; 240 v power tranny for 2A3 or 45 | rick57 | Swap Meet | 0 | 8th November 2006 01:07 AM |
| horisontally mounted sub possible? | Jennice | Subwoofers | 7 | 22nd September 2004 06:11 AM |
