breaking in audio capacitors - Page 4 - diyAudio
Old 6th December 2012, 11:14 AM   #31
Vincent77's Avatar
I envy you guys (sort of). You can use any cap and call it good. I had to spend time and money to find very good sounding ones, because I can clearly hear the diferences.
I have noticed that a cap keeps its sonic "signature" in different circuits, and the more expensive ones *usually* sound better.
I think the differences come from the manufacturing process (tolerances, winding tension, geometry, inductive or not, etc.), material quality and purity (a copper foil doesn't sound like an aluminum metalized film) and the dielectric itself, of course...
Old 6th December 2012, 11:28 AM   #32
DF96 is offline DF96  England
You mean just with your ears?
Old 6th December 2012, 11:33 AM   #33
Vincent77's Avatar
No, I taste them too.
Old 6th December 2012, 12:05 PM   #34
TonyTecson's Avatar
syrupy or chocolaty?
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 6th December 2012, 01:12 PM   #35
Magz is offline Magz  United States
Some of the PIOs, especially the wax ones, have quite a nice smell...as long as we're using all our senses here...
Old 6th December 2012, 01:39 PM   #36
Break in/breaking = hitting it very hard with a very big mallet.
Or, as mentioned earlier.
Give your ears time to adjust to the new sound. The Brain has a wonderful capacity for filtering out what it thinks does not belong there.
Yet another wonderfully unhelpful post?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 6th December 2012, 04:56 PM   #37
Davec113's Avatar
I have spaces for 2 sets of coupling caps in my Aikido and there are clearly audible differences between SOME caps, others not so much.
I tried a cheap Solen MKP vs RelCap PCUs and the difference is not subtle.
I think it's also interesting with all the talk of "magic". I suppose magic is the answer for everything we don't clearly understand? What did Clark say? "Any sufficiently advanced technology is indistinguishable from magic." While a healthy dose of skepticism is desirable, so is an open mind.
Old 6th December 2012, 05:04 PM   #38
john curl's Avatar
Hang in there, Vincent77. I agree with you.
"Condemnation without Examination is Prejudice"
Old 6th December 2012, 05:37 PM   #39
you agree that waiting longer than 50hrs of listening that further changes will be audible?
And how does one reverse the change that one has heard to determine that the sound effect is real?
regards Andrew T.
Old 6th December 2012, 05:45 PM   #40
Reality first!
ClaveFremen's Avatar
+1
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Quality capacitors without breaking the bank philb Parts 7 1st June 2014 08:00 PM
Anyone with experience breaking in capacitors out of circuit? phrarod Tubes / Valves 102 17th March 2011 01:52 PM
Best capacitors for Audio?... VS Pass Labs 15 9th January 2005 02:08 AM
Audio Capacitors RichH Solid State 2 11th March 2001 08:22 AM
Copyright 1999-2017 diyAudio
