Noob Toob Question
Noob Toob Question
Old 8th November 2003, 03:09 AM   #1
Beau is offline Beau
Default Noob Toob Question
Just wondering, I am considering building a tube preamp kit, but I want to use it with monoblock amps and need to have a volume control, is it as simple as wiring in a pot on the input or output?(what value?) Also I want to mount the tubes (12ax7) on the top plate of the chassis, off the PCB, can I just use flying leads onto a socket for the valves with no ill effects?
TIA Beau.
Old 8th November 2003, 09:34 AM   #2
Brett is offline Brett
Brett's Avatar
Default Re: Noob Toob Question
If you're going to drive more than a couple of inches of cable, put it at the input.
But I have to ask, do you really need a linestage? Almost all systems I've ever seen have way too much gain and all you'll end up doing is attenuating it away adding noise and lowering resolution.
TIA Beau.
12AX7's are probably the worst choice for a tube for a linestage; too much gain and way too high an output Z to be useful, unless it uses CF's, in which case it will just sound lousy. A single stage 6BX7/12B4A/6H30 resistively loaded would make a much better line stage (speaking from long experience) and give a more useful gain structure.
Why are you using a PCB? is it part of a kit/project?
The tubes can be mounted to the top plate and flying leads used if required, but why not simply buy some PCB mount sockets and solder them directly to the board?
If the design you're using includes a phono stage, I'd need to see the design before I comment further.
Old 8th November 2003, 12:38 PM   #3
On Hiatus
SY's Avatar
Noob Toob Question
Brett: A line stage can still be a useful thing for those of us with sources that vary greatly in output (like tube tuners with 500mV outputs). But I'm with you for the vast majority of other times; line stages are a relic. Buffering is nice, though.
Your comments on the 12AX7 as a line amp are true IF you're not going to use feedback. But if you are, the 12AX7 can work quite well, its high gain being an asset.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 8th November 2003, 01:25 PM   #4
Brett's Avatar
My system has 9 different sources plugged into it, and almost never do I have it turned up within 3dB of full volume (on the vol control)
Take a turd and smother it in peanut butter, and it's still a turd.
Old 8th November 2003, 01:48 PM   #5
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Brett, i seldom disagree with you but to liken NFB to peanut butter is a bit extreme
Old 8th November 2003, 02:10 PM   #6
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
it's really a bit strange though...why would you want a 12AX7 as a linestage?? a guitar distortion circuit would more likely fit the bill...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 8th November 2003, 04:02 PM   #7
On Hiatus
SY's Avatar
Noob Toob Question
There are a lot of classic preamps with 12AX7 line stages and feedback. Whether they fit your personal creed is not relevant- that they work well for many, many people is attested to by the longevity and continuing high regard for Marantz 7, Dyna PAS and PAM, Audio Research SP-3 and SP-6 series...
I don't see much resemblence between these classic circuits and guitar distortion boxes, but I'm not always in search of novelty for its own sake. Boring old circuits are often that way just because they work so well and without much fuss.
Old 8th November 2003, 11:17 PM   #8
li_gangyi's Avatar
hmmm...you got a point there SY...but I wouldn't consider the 12AX7 and "audiophile" tube...anyways...most of the time I see them on guitar amps only...why is that so??
Old 8th November 2003, 11:43 PM   #9
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Mediocrity here we come....goodbye excellence.
Frank
Old 9th November 2003, 12:07 AM   #10
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Polished peanut butter
Yuck! Can't stand peanut butter. Over here, we attempt polishing. That doesn't work either.
In a DIY system, the expensive degradation caused by a pre-amplifier is unnecessary. The only excuse is to allow power amplifiers to be near loudspeakers. As you have monoblocks, you could put them near the loudspeakers and reduce the length of (thick, expensive) loudspeaker cable, but at the expense of needing a line stage that can drive the capacitance of a long cable. 12AX7 can't really swing enough current to do this properly. You need something a bit beefier, configured as a cathode follower - ECC88, 6SN7 are possibilities, but one of the Russian muscle triodes such as 6S45 could be even better.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Noob Toob QuestionHide this!Advertise here!
OB noob question Pault Multi-Way 8 14th March 2009 12:15 AM
Noob and toob genmin Introductions 1 21st January 2009 10:18 PM
Noob question dumbo800 Tubes / Valves 6 12th August 2008 02:43 AM
Noob Question USlatin Everything Else 3 13th November 2007 04:01 PM
Transformer Coupling and Headphones? (Toob Noob) GD3 Tubes / Valves 10 20th May 2006 11:30 AM
