diyAudio Sponsor
Old 8th November 2003, 01:41 AM   #1
PassFan is offline PassFan  United States
Default Transformer Question
I have a couple of 370 volt transformers and need 300volts for the circuit. Can I load these 370v's down to 300v's, and how?
Old 8th November 2003, 03:06 AM   #2
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
resistors and/or regulators.
2 0D3's with a pass tube or transistor on top would probably be the best.
Old 8th November 2003, 05:05 AM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
370VAC? Choke input, maybe with tube rectifier.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 8th November 2003, 05:31 AM   #4
li_gangyi's Avatar
Most of the time though...the tube will probably do fine with a little voltage more...depends on the design as well...if it is already near the limits...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 8th November 2003, 06:12 AM   #5
Brett's Avatar
All of the above will work in lots of different configurations. But how about downloading PSUD2 from www.duncanamps.com and model it for yourself? The characteristics of the components in the PSU, eg a choke's DCR will affect the final voltage along with the current draw.
Old 8th November 2003, 11:10 AM   #6
Thanks for the tips guys. I actually have psud version 1 but wasn't having much luck with it. I will try out version 2. As far as regulation is concerned the cure must be significantly less than the 58 dollars for a new transformer so loading it down will be a better choice for me.
Old 8th November 2003, 08:26 PM   #7
Happy Ears's Avatar
Default Re: Transformer Question
Hi PassFan , what circuit have you got in mind ?
Happy Ears
Old 8th November 2003, 11:11 PM   #8
li_gangyi's Avatar
Yeah..if you passed us the circuit...maybe we could determine that you don't even have to drop the voltage at all~!!!
Old 9th November 2003, 02:49 AM   #9
370V rectified is going to go upwards to 400-450VDC dependeng on how you rectify it and dropping voltage down to 300 is quite a stretch. You would probably be better off by reevaluating your circuit and either making allowances for higher voltage or getting a different transformer.
Old 9th November 2003, 05:21 AM   #10
li_gangyi's Avatar
it might drop a bit if you use a tube rectifier...
Transformer question? mcameron Parts 5 23rd January 2005 07:52 PM
transformer question xcortes Chip Amps 0 31st October 2004 05:04 AM
Transformer Question TunaFish Tubes / Valves 15 18th June 2004 11:20 PM
Transformer Question toque_101 Chip Amps 2 26th January 2004 05:21 AM
Page generated in 0.09891 seconds (76.23% PHP - 23.77% MySQL) with 11 queries
