Altec 15067 transformers
Old 1st December 2012, 10:50 PM   #1
tom42107 is offline tom42107  United States
Default Altec 15067 transformers
I have two of these Altec 15067 transformers that have been sitting on my parts shelf for a while. They are intended for 70v applications. I googled them and saw someone had the same ones listed on E-Bay as tube output transformers for 2A3 tubes, 2500 ohm primary and 4, 8 and 16 ohm secondary. It didn't say anything about them being modified for separate primary and secondaries. I checked all four wires coming out and there is continuity on all wires. I have heard of using 70v transformers as output trans. but they had primary and secondary sections. Being a new DIY'er I've never opened up a transformer before. How possible is it to modify these to be SE transformers and is it worth it? I've attached a picture of my transformers.
Tom
Old 2nd December 2012, 02:08 PM   #2
tomlang is offline tomlang  United States
tomlang's Avatar
First off, this transformer does not have a gapped core so it will not work for SE duty.
I have become interested in using line transformers as output transformers and made a spreadsheet for several that are available here in the USA. I don't have the 15067 data, but I have attached data for the 15066. As you can see it is far from 2500 ohms as it is a 600 ohm p-p transformer with an 8 ohm load on the 8 ohm tap. If you put a 32 ohm load on the 8 ohm tap you would have 2400 ohms reflected back to the primary.
For more information:
http://home.alphalink.com.au/~cambie/6AN8amp/M1115.htm
Cheap Output Transformers
Parsimon: An Ultra-Cheap DIY Class AB PP Pentode Power Amp - AudioKarma.org Home Audio Stereo Discussion Forums
Altec 15067 transformersHide this!Advertise here!
WTB Altec 15335A transformers Larss Parts 0 31st May 2012 06:57 PM
FS Altec Lansing Transformers (15095, 15015) kazoo Swap Meet 4 11th January 2012 06:28 PM
Altec Plug In Transformers imix500 Swap Meet 2 24th April 2011 06:55 PM
ALTEC LANSING 15356 Transformers (for Gigawork DAC, etc) wushuliu Swap Meet 2 14th October 2010 12:52 AM
Altec 811B horns and Altec 414z 12" Speakers xecluded Swap Meet 0 21st September 2008 06:21 AM
