Looking to build my first tube amplifier - Page 5 - diyAudio
Old 3rd December 2012, 11:01 AM   #41
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
hmm, you can get a cheap Amplimo 40watt, 4K, PP-UL.... 73,21EUR
3A524UL : Balans-uitgangstrafo voor buizenversterkers - Ringkerntrafo.nl
a suited Amplimo power supply trafo would cost about the same
but the Dutch shipping...could be serious money ? (these are looking heavy)
roughly, 200EUR is 160 GBP
shipping could be like 50 EUR, maybe
that would be 200 GBP spent on trafos
to compare, cheap Brittish trafos would cost around 50 GBP, each
btw, on my part, shipping from Poland or Germany is cheaper
even HongKong sometimes cost the same as local shipping
Old 3rd December 2012, 11:21 AM   #42
that said, Edcor midbudget small SE trafos are so cheap it could be the best choice of all, cost wise, shipping included
maybe this one would be great, 15watt SE, 3.5K to 4ohm ...well suited for EL34 SE ? (please note question mark )
http://www.edcorusa.com/p/524/gxse15-4-3_5k
power trafo cost a bit more
and taxes are not included
Old 3rd December 2012, 11:26 AM   #43
cb5 is offline cb5  United Kingdom
I have been thinking of these, even with shipping the the UK they are still very cheap !!!!
Old 3rd December 2012, 11:30 AM   #44
Would this transformer http://www.edcorusa.com/p/524/gxse15-4-3_5k
Be suited to this circuit?
6550/EL34 Mini Single Ended Amplifier D.I.Y
Old 3rd December 2012, 11:39 AM   #45
I have contact scott17 about one of his kits, this may be the best option for now!
Old 3rd December 2012, 11:50 AM   #46
freax's Avatar
Good to hear that, I've found that its a good basis to start both enjoying and learning about tube audio.
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 3rd December 2012, 02:05 PM   #47
But this is expensive as i will probably get hit with import tax somaybe i should build something cheap and simple with parts i can get from uk !
Old 3rd December 2012, 02:13 PM   #48
I'm not sure if this has been suggested yet, I didn't read through the thread, sorry.
As a first tube amp, the Simple SE from Tubelab would be a great place to start.
Simple SE
He also has a forum here in the Vendor's section. Very well supported, lots and lots of successful builds.
It's just the circuit board which I'm sure would be relatively inexpensive regarding import duty. You source all the parts locally.
Scott
Old 3rd December 2012, 02:17 PM   #49
I should have mentioned Tubelab also offers a Simple Push Pull board, for more output power.
Whatís the best tube amplifier you can build? anders.a Tubes / Valves 42 29th September 2006 09:08 PM
I want to build my own ALL TUBE bass amplifier juicy1484 Instruments and Amps 1 2nd November 2005 07:15 AM
Copyright ©1999-2017 diyAudio
