Looking to build my first tube amplifier - Page 3 - diyAudio
Old 2nd December 2012, 10:58 AM   #21
cjkpkg is offline cjkpkg  United States
here's my el84 p2p build.
Old 2nd December 2012, 11:46 AM   #22
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
or this looks like fun
probably not the best
but simple, and easily 'updated' later on
EL84 driving EL84 SEP
Old 2nd December 2012, 12:15 PM   #23
freax's Avatar
KT88 SE Basic or Master Kit
You could always get the basic kit from Scott17
If I were the OP i'd be thinking about a single tube envelope per channel amplifier/audio triode + output pentode in one envelope, like the ECL82's
That way he can use 2 tubes, a SS rectifier, and spend a total of about $50-$100 on parts at most for 3.5 watts output in Single Ended.
http://bruceinjapan.blogspot.jp/2012...-tube-amp.html
http://nmwilliam.tripod.com/ecl82.html
'nuff said, kits rule!
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 2nd December 2012, 12:32 PM   #24
tomlang is offline tomlang  United States
tomlang's Avatar
Some of us are building a "5 watt" amp using cheap line transformers at AK:
Parsimon: An Ultra-Cheap DIY Class AB PP Pentode Power Amp - AudioKarma.org Home Audio Stereo Discussion Forums
Old 2nd December 2012, 01:39 PM   #25
small cheap SE output trafo in EU would cost 30-50EUR, each
Old 2nd December 2012, 02:44 PM   #26
yoaudio is offline yoaudio  United States
yoaudio's Avatar
Originally Posted by cb5 View Post
Hi Everyone,
Im looking to build my first tube amplifier to power a pair of 8R bookshelf speakers.
Does anyone have any reccomendations?
If you have the Omega Grande 8R Single Driver Speakers, Highly efficient. 96 dB sensitivity.
 8 inch Fostex drivers. (The Hemp version, not the Alnico.)
Then I would recomend a RH84 build.
As Zekk put it in another thread-
Originally Posted by Zekk View Post
I'm exhilarated by the great sonics coming out of my humble Magnavox 196 BA re-wired to a RH84SE circuit.
Only changed the choke to a Hammond 10H@150mA.
Despite the original PT of 260-0-260v, with a B+ of 276v, it did'nt lose out much to my regular McIntosh MC-30 monobloc.
What surprised me most was how quite it is, not a hiss from my 101dB Altec 604-E! Incredible!
Can't beleive that 3 tiny-wimpy tubes can thump my Mac !?
Bass is a big "WOW". s
This first listen to a SET have totally changed my mentality of the low watters! I'm now confident enough to build a RH66 if I can find the schematics for it. Can make use of the quad of KT66 Gold Lion from the MC-30.
This hobby is fantastic and wish I could have taken up electronics instead of structural engineering, 40 yrs. ago.
Cheers!
Zekk
In a output transformer shoot out in another forum--
On an RH84 build of mine, I recently tried the Hammond 125ESE, Edcor XSE15-8-5K, Edcor GXSE15-8-5K, and the Transcendar 5k-8ohm 10W SE Trasnformer.
Both the 125ESE and the Edcor XSE15-8-5k sounded very similar to each other with the Edcor having a bit more high-end detail. Both seemed to drop in performance on the low end.
The Edcor XSE15-8-5k costs half the Hammond for similar performance so I view the Edcor XSE as the better value compared to the Hammond. It is handy to have the multiple impedance taps on the Hammond for experimenting.
The Edcor GXSE15-8-5K was an overall good performer with a much improved bottom end compared to the 125ESE and the Edcor XSE15-8-5K.
The Edcor GXSE15-8-5K bottom and mid range sound was close to the Transcendar with the Transcendar sounding the best of the bunch with more high-end detail.
Old 2nd December 2012, 07:41 PM   #27
cb5 is offline cb5  United Kingdom
THANK YOU everyone, I will be looking through all the different options posted many thanks
Old 3rd December 2012, 09:39 AM   #28
Bruce in Japan: ECL82 / 6BM8 Tube Amp
Single Tube amplifier
Im thinking of building this to start with, could i just use cheap output transformers that are available in the UK?
Is there anything specific i need to be aware of?
Old 3rd December 2012, 09:45 AM   #29
please note....special tube
some of these 'compactron' tube types use weird tube bases
and those who don't, they can be 'in high demand'
Old 3rd December 2012, 09:49 AM   #30
Okay, maybe i should look at something else?
It just seems simple!
Whatís the best tube amplifier you can build? anders.a Tubes / Valves 42 29th September 2006 09:08 PM
I want to build my own ALL TUBE bass amplifier juicy1484 Instruments and Amps 1 2nd November 2005 07:15 AM
Copyright ©1999-2017 diyAudio
