#11 |
Hi, maybe Angela SE EL34 tube amp... it is very simple and easy for P2P soldering... of course good sound too.
#12 | |
#13 | |
Sure, this kind of amp will make "sound" with any speaker. But it won't make MUSIC. |
#14 |
A push pull EL84 will get you about 15 watts. A Dynaco ST-35 would be kinda easy to wire point to point. You might be able to change the 7247 to a 6DJ8. Have to make a few changes in the circuit.
Dynaco ST35 Tube Amplifier Schematic and Manual Last edited by DeathRex; 28th November 2012 at 04:40 PM. |
#15 |
Clone a Magnavox 196-xx or 197-xx SE amp. But even with a cheap and low parts count SE amp, your still going to be close to $200 for parts.
#16 |
#17 |
So many options, but everything seems over my head!
#18 |
The caps go on the other side.............. of the PCB. I check component spacings and count, look for missing components prior to etching the PCB's. I use the brittle green florist foam to push the leads into to do a mock-up.
Example of the KEG-EAR amp in process attached.....
SO many tubes, SO little time!!! |
#19 |
My 6LU8 Spud can be built for close to nothing and provides good sound for the money. I think I spent maybe a grand total of $200~$250 including walnut chassis, connectors, tubes, etc.
~Tom
21st Century Maida Regulator, Universal Filament Regulator, 300B Driver PCBs, and more... Neurochrome : : Audio - http://www.neurochrome.com/audio - Engineering : : Done : : Right |
#20 |
That's a very cool design Tom. The Edcor GXSE series might be a mid-point in the cost factor and offer a bit more performance compared to the XSE as an option.
I just checked ESRC, those tubes are only 5 bucks! Excellent. Scott Last edited by scott17; 2nd December 2012 at 06:20 AM. |
| What’s the best tube amplifier you can build? | anders.a | Tubes / Valves | 42 | 29th September 2006 09:08 PM |
| I want to build my own ALL TUBE bass amplifier | juicy1484 | Instruments and Amps | 1 | 2nd November 2005 07:15 AM |
