Pyramid-IX monoblock, 200W from 4x GU-50 - diyAudio
View Poll Results: Which side should be the front?
Long 12 29.27%
Short 29 70.73%
Voters: 41. You may not vote on this poll
Old 25th November 2012, 11:57 PM   #1
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Default Pyramid-IX monoblock, 200W from 4x GU-50
Hi!
I am building a prototype of the amp, it will be monoblock, 200W output, 4xGU-50.
I have a dilemma, which side should be the face, with front panel?
Usually monoblocks have short face. But if to make the front panel on the long side it will be 19" rack mountable. Which road should I choose?
The front panel will contain only power switch and volume control. Rear panel will contain power socket, fuse, output binding posts, RCA and XLR sockets, RCA-XLR switch.
The Devil is not so terrible as his math model is!
Old 25th November 2012, 11:59 PM   #2
Bigun is offline Bigun  Canada
Bigun's Avatar
Wow, this is an interesting amp
With the layout you have chosen, I vote for short face as the front, then when you look at it you see row of shielded tubes and behind a row of monsters!
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 26th November 2012, 12:05 AM   #3
Ejam is offline Ejam  Australia
Default 200W Amp Schematic?
Wavebourn
Any chance of a schematic or a description of your new creation?
Old 26th November 2012, 12:15 AM   #4
Wavebourn's Avatar
They will not be shielded, I just put sockets to see sizes. One will be cat's green eye.
If to make the face short It would be better to put input sockets on the front panel, but power switch on the rear one.
Originally Posted by Ejam View Post
Wavebourn
Sure, no problems. Everything will be in public domain with disclaimer, "800 Volts kills!"
May be I will sell PCBs, if somebody wants.
Old 26th November 2012, 12:55 AM   #5
AJT is offline AJT  Philippines
AJT's Avatar
can you tell part numbers of those Edcor's please......
the best advertisement for a good audio design is the number of diy'ers wanting to build it after all the years....never the say so of so called gurus....
Old 26th November 2012, 01:03 AM   #6
Wavebourn's Avatar
Special order for power transformer. Output transformer is 4k2 for 100W from 20 Hz. From 40 Hz it will work nice for 200W, but I should try first. CXPP-100-MS-4.2K
Old 26th November 2012, 01:18 AM   #7
AJT's Avatar
thanks, i like the beige colored traffos.....
Old 26th November 2012, 02:40 AM   #8
So, I am curious. Will this be pentode operation of the ordinary sort, or incorporate some of your Schade magic? I suppose what I am asking is, Can you give some basic circuit description? I have read more than a couple of threads regarding the gu-50. I have noticed that you have put quite a bit of time into developing circuits with this valve and will follow this thread. GU-50...Wavebourn...these two are always found together, it seems.
Old 26th November 2012, 02:48 AM   #9
Wavebourn, I have been meaning to ask about the GU-50 sockets. Is it necessary to have all the metal support pieces, or can they be removed to make a more "normal" looking socket? Thanks, gary
Old 26th November 2012, 02:48 AM   #10
Wavebourn's Avatar
Yes, it will be in pentode mode, with local feedbacks across output tubes. The difference from previous Pyramids, MOSFET followers to drive output tubes, and 2 tubes in parallel for twice higher power. However, the power will be rated for frequencies from 40 Hz, instead of 20 Hz, but it is plenty, since such amps either drive Magnepans at homes, or concert line arrays. For subs (frequencies below 40 Hz) I believe class D amps are better.
I would not suggest to remove all that "extra metal" from sockets: pins are thin, and key is on the glass, so it is easy to insert tubes wrongly damaging the amp.
GU-50, GM70 and KT88 nina Tubes / Valves 47 30th December 2016 05:59 AM
GU 50 monoblock gedd Tubes / Valves 8 21st October 2011 11:08 AM
GU 50 output modification beamnet Tubes / Valves 22 15th January 2010 04:02 PM
Use of 12j1l and gu-50 tubes gemby Tubes / Valves 6 26th October 2008 10:56 PM
GU-50 output trafo croccodillo Tubes / Valves 7 11th May 2007 09:55 AM
Copyright 1999-2017 diyAudio
