| View Poll Results: Which side should be the front? | |||
| Long |
10 | 28.57% |
| Short |
25 | 71.43% |
| Voters: 35. You may not vote on this poll | |||
#21 | |
Yes, nice tubes. They were designed by Telefunken for military applications. They easily survive red anodes dissipating 100+ Watts, after that work like nothing happened. Good luck with your Bass Guitar amp Wolfgang!
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#22 |
Hi Wavebourn,
see this thread, there are Pics an a digram of my test setup. Real bass amps have tubes – semiconductors are musical director trainees I came across about 30 GU50, so enough for further testings. By the way, I never managed to blew up even a single valve , as you stated they rugged like a tank. (what they are made for) ![]() Please keep us informed with your neat little beasts! ![]() 73 Wolfgang
Ground your devices before they ground you Last edited by Funker; 26th November 2012 at 05:52 PM. |
#23 | |
I think I will probably design the chassis for 2 versions of orientation, with both versions of holes pre-cut. Extra hols will be closed by false-panels. Such a way I will have more freedom in the future. And 2 models of the amp on the same chassis.
#24 |
good job you don't design cars :-)
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#25 |
I never saw cars with sockets on sides. Or what do you mean?
![]() Actually, I worked for an automotive company. But I did not design cars. I designed information systems to steal money when manufacture and sell cars (just kidding - good information is valuable both to steal and to save money)
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. Last edited by Wavebourn; 27th November 2012 at 02:23 AM. |
#26 | |
#27 |
Here are my thoughts:
1. I would turn all the components 90° on the chassis so you can space out the output tubes. I think they are spaced too close together and need more ventilation. 2. I would locate the two transformers all the way to the back and at opposite sides with the heat sink between them. 3. I would orient the front of the chassis on the long side so that all the output tubes are facing you and are equidistant from your point of view.
#28 | |
#29 |
Wavebourn,
Look forward to seeing the end result of this monster Pyramid. Really enjoying the GU-50 SE amp u helped design for me. Currently using 6E5P in triode as drivers. Dynamic, clear, powerful. All the best with this project :-) |
#30 |
Interesting suggestion; I've also found that more powerful the tube amp is, the better the sound quality, esp at lower levels. Obviously the perception to overload is far reduced, but other boundary conditions must appear to be better optimised. Distortion may already be very low and undetectable; but what creates the transparency when good quality commercial components are used ? No deoxidised rubbish, no silver, nor gold connections. Yes, all my amps use input transformers, balanced line.
The sound quality of my Vampire 500W is astounding when at low sound levels is put against the original Mullard 20W design, or the GEC 88-50, 3 stage amp which is an excellent sounder. In the mid 1950's-60's these were considered, well designed. The 500W is the final design, the most complicated I've ever built, the best and there we have it. Over decades I accumulated quite a collection of homebrewed tubed HiFi stereo amps, many are sold and my own favourite chassis is the two chassis 500+500W; I chassis 2x25W;2x7W..etc ...It's taken a long time to reach nirvana, what I consider the best quality tube amp for a given set of loudspeakers. Others may have their liebling amps too. richy |
| GU-50, GM70 and KT88 | nina | Tubes / Valves | 44 | 27th September 2012 05:14 PM |
| GU 50 monoblock | gedd | Tubes / Valves | 8 | 21st October 2011 10:08 AM |
| GU 50 output modification | beamnet | Tubes / Valves | 22 | 15th January 2010 03:02 PM |
| Use of 12j1l and gu-50 tubes | gemby | Tubes / Valves | 6 | 26th October 2008 09:56 PM |
| GU-50 output trafo | croccodillo | Tubes / Valves | 7 | 11th May 2007 08:55 AM |
