Pyramid-IX monoblock, 200W from 4x GU-50
View Poll Results: Which side should be the front?
Long 13 30.95%
Short 29 69.05%
Voters: 42. You may not vote on this poll
Old 26th November 2012, 08:53 AM   #11
HpW is offline HpW
Originally Posted by Wavebourn View Post
Hi!
I have a dilemma, which side should be the face, with front panel?
Usually monoblocks have short face. But if to make the front panel on the long side it will be 19" rack mountable. Which road should I choose?
The front panel will contain only power switch and volume control. Rear panel will contain power socket, fuse, output binding posts, RCA and XLR sockets, RCA-XLR switch.
Below is a picture of my modified Cary SLM-100 with following changes:
1) Input on the front to have now signal trough the power & output and also a very short connection to the first input tube
2) Power switch on the back to avoid long power cables trough the chassis
3) the standby (connection to ground with a lift up resistor) switch & cables connection has been shorted and now use a relays.
Still open & research in progress (may some one helps in this regard ): the schematic for the real XLR / symmetric input while have only 2 * 6SN7 tubes...
HpW
Old 26th November 2012, 09:22 AM   #12
costis_n is offline costis_n  Greece
Having faced the same dilemma recently, I can say that the only way that sensitive signals do not pass near the power supply AND not have the input jacks right on the front, is to have the long face forward. Then again, you can take a cue from Ming-Da preamps (yes, them), and have the narrow face front, but the inputs on the side forward.
Old 26th November 2012, 10:16 AM   #13
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
HpW
makes a lot of sense to me, this is also my prefference, but you know there are folks that find this arrangement ungly no matter how i try to explain the advantages...oh well......
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 26th November 2012, 12:37 PM   #14
nottolkien is offline nottolkien  United States
When I think in terms of MOSFET followers in this type of application, I think in terms of the TubeLab "power-drive" (because I am somewhat familiar with it). Whatever scheme specifics may be, such a follower concept does seem to open the doors to a very broad selection of drivers and also seems as if it should be "sonically invisible".
Two questions:
.......1) Is it sonically invisible?
and, 2) Are you contemplating a regulated screen supply?
It seems to me that screen supply regulation might represent the last link in a design of this basic description: dynamic maintenance of impedance, that is to say.
Old 26th November 2012, 01:06 PM   #15
Bigun is offline Bigun  Canada
Bigun's Avatar
power switch on back is a nuisance, have to reach over and behind everything to turn on/off
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 26th November 2012, 02:26 PM   #16
HpW is offline HpW
Well, for this I have a common power plain (and power filter) with all audio stuff on and a single common power switch for all.
HpW
Old 26th November 2012, 03:09 PM   #17
Funker is offline Funker  Germany
Default which side to front?
Hi Waveburn,
Wow, 4 GU50 that will give your amp the real grunt. For my taste, I would prefer it with the narrow side to front.
I made a test setup with 6 of the GU50. I drive them hard into grid current (B2) They drive 450W into the Load at 1000V plate and 250V g2 . What an amazing valve. My aim is to build a Bass Guitar amp with these.
73
Wolfgang
Hi!
I am building a prototype of the amp, it will be monoblock, 200W output, 4xGU-50.
Ground your devices before they ground you
Old 26th November 2012, 03:13 PM   #18
Parafeed813 is offline Parafeed813  Netherlands
Talking perfect timing
Yesterday I was -just one more time- thinking what to do with the two big PTs that I have laying around. Wavebournes posts got me interested in the GU-50, so I checked out their availability, prices, specs, compatibility with my PTs. I could do 4 or 6 per channel. When I woke up this morning I say this thread... Now that's what I call a good start of the day
I'll be following this one.
Old 26th November 2012, 03:57 PM   #19
djn is offline djn  United States
djn's Avatar
I just voted for the wrong side. I would make the short side the front as it shows off those tubes nicely.
Old 26th November 2012, 04:21 PM   #20
richwalters is offline richwalters
richwalters's Avatar
Although I voted long front ...this 500W amp is 19"x18" square ...snags, no room available at the rear for AC socket and opposite side XLR inputs, for listening room and stage aesthesics I avoided front panel clutter as rt'angled entry of both IEC and XLR are around.
I'd admit getting the mechanical size of this amp into a 19" rack criteria wasn't easy.
richy
Pyramid-IX monoblock, 200W from 4x GU-50Hide this!Advertise here!
GU-50, GM70 and KT88 nina Tubes / Valves 55 19th February 2017 11:16 AM
GU 50 monoblock gedd Tubes / Valves 8 21st October 2011 10:08 AM
GU 50 output modification beamnet Tubes / Valves 22 15th January 2010 03:02 PM
Use of 12j1l and gu-50 tubes gemby Tubes / Valves 6 26th October 2008 09:56 PM
GU-50 output trafo croccodillo Tubes / Valves 7 11th May 2007 08:55 AM
