The Best tube/valve sound!? - diyAudio
Old 23rd November 2012, 09:30 AM   #1
Gost22 is offline Gost22  Bolivia
Banned
Question The Best tube/valve sound!?
Hi all!
What is the best tube/valve for preamp or line-stage i.e. that gives the best sound?
Is this a good schematics?
Why are the (1/2-6DJ8 + 1/2-6DJ8) tube/valve in this configuration (schematics) connected in parallel?
(1/2-6DJ8) + (1/2-6DJ8) in paralle.
It can be replaced 6DJ8(6922) with PCC88 and who changes that are needed in the schematics?
thank you!
Old 23rd November 2012, 09:38 AM   #2
AJT is offline AJT  Philippines
AJT's Avatar
define "best".....
the best advertisement for a good audio design is the number of diy'ers wanting to build it after all the years....never the say so of so called gurus....
Old 23rd November 2012, 09:58 AM   #3
Banned
Originally Posted by Tony View Post
define "best".....
Hi Tony!
Give an opinion on this schematic or a suggestion for pain tube/valve preamplifier, line-stage or buffer.
thank you!
Old 23rd November 2012, 09:59 AM   #4
DF96 is offline DF96  England
That was going to be my question too!
The circuit looks like a good example of how not to do a line stage. For example, choose a valve with a low output impedance then put it into a circuit which increases it dramatically.
Old 23rd November 2012, 10:25 AM   #5
AJT's Avatar
Originally Posted by Gost22 View Post
Hi Tony!
thank you!
what is best for me may not be best for you, we are not the same person...
a Broskie CCDA works fine for me, i can hear no difference between it and the Aikido, both Broskie's....
the scheme shown below has a B+ of about 130volts, you can replace the diodes in the cathode of the input tube with 82 ohm resistors...
tube can be ECC88, 6922, 6dj8, etc...
Old 23rd November 2012, 11:02 AM   #6
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
wow, a working curcuit looks 'appealing'
why the 1K5 att input pot ?
how can you use such small one ?
Old 23rd November 2012, 11:14 AM   #7
What is the purpose of the common-mode choke L1? It appears to be in the wrong place to attenuate rectifier spikes, and it will have little effect on smoothing.
Old 23rd November 2012, 11:25 AM   #8
don't know, but is it good to have a choke in the grounding line ?
Old 23rd November 2012, 11:47 AM   #9
SY's Avatar
I want to know why the OP keeps opening thread after thread asking the same question.
"Pity, wrath, heroism, filled them, but the power of putting two and two together was annihilated."- EM Forster
Old 23rd November 2012, 12:04 PM   #10
Perhaps he doesn't like the answers he gets, so like a politician keeps asking the same question again and again hoping for a different result. Or maybe he has poor memory?
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Instruments and Amps 17 20th April 2015 04:11 AM
10 in FR in tqwt speakers /sound of the valve soulsheiksan Swap Meet 0 26th September 2011 08:52 PM
old Valve/Tube Amps Alwood Swap Meet 5 25th December 2010 02:04 PM
can't find valve art tube - and glowey tube pic wicked1 Tubes / Valves 23 10th February 2009 12:54 AM
sound of the valve 10 inch soulsheiksan Full Range 0 19th December 2005 05:19 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
