diyAudio Sponsor
Old 10th November 2003, 12:05 PM   #31
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
http://www.tubebuilder.com/images/sc...d/el84_se3.gif
...still looking for the holy grail.
Old 10th November 2003, 12:10 PM   #32
diyAudio Senior Member
fdegrove's Avatar
There was an amp built by Stigla right here in this forum. If Frank or someone can post a link to this thread it would be nice.
STIGLA
Not sure which one is the right one though....
Frank
Old 10th November 2003, 07:28 PM   #33
Raj1 is offline Raj1  United Kingdom
hi,
Cheers Frank, had a brief buthcers thru the link, couldn't find that thread though.........
Mohan can you please post that 45 circuit to me????
Raja
Old 29th November 2003, 09:26 PM   #34
qwad is offline qwad  Australia
Hi all; call me a dummy but I can't be able to download the SE 6080/6AS7G SE circuit article for those who requested a copy by far the simplest as far as I am concerned is you all email me at tomcat@dodo.com.au and i'll post you the scanned article individually as I AM A BIT OF A DUMMY WHEN IT COMES TO TRYING TO ZIP IT ALL UP AND THEN FIND ING IT AGAIN TO POST HERE also please note that in order to double the output power from 4w to 8 is simply acheived by swapping the op tube for the 6336 which is similar but capable of higher output the output trafo is not specified in the article because HI-FI WORLD wants to make money on it so you would have to buy it from them but I have it on reasonably good authority that it should be around 5k, and obviously gapped for se operation.... sorry guys but thats the way the dice rolled... cheers and best regards tomcat
we all have problems only some people have more than most....
long live the Magyar (Hungarians) in the world!
Old 29th November 2003, 09:44 PM   #35
fdegrove's Avatar
Here's what you can do:
I'll send you an e-mail, you send the file and I'll try to post it here.
Saves you alot of time if I succeed.
Frank
Old 29th November 2003, 10:14 PM   #36
OK; you're on! cheers and thanks for the offer tomcat
Looking for a simple circuit Skitch72 Tubes / Valves 19 12th August 2009 08:31 PM
Simple PCM2707 bus powered I2S source, is this circuit good or bad? JogeirEmil Digital Source 6 2nd December 2008 04:12 PM
HELP-- I need a simple 50W AMP circuit --- MTO audio Solid State 5 9th August 2007 07:46 AM
Help me with simple circuit valterdaw Car Audio 2 22nd August 2006 08:15 AM
Good but simple subwoofer chip amp. circuit suggestion Alvin Chip Amps 2 17th January 2004 02:04 PM
Page generated in 0.08466 seconds (74.41% PHP - 25.59% MySQL) with 10 queries
