single ended transformer driving 32ohm speaker - diyAudio
Old 21st November 2012, 12:04 AM   #1
ba3jar is offline ba3jar  England
Default single ended transformer driving 32ohm speaker
Hi
where can i find a company that make a custom transformer for tube amps , a single ended 50watt that drives a 32ohm speaker?
thank you
Old 21st November 2012, 01:41 AM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I have no idea about Europe, but in USA you can order them here:
EDCOR
The Devil is not so terrible as his math model is!
Old 21st November 2012, 01:52 AM   #3
djmiddelkoop's Avatar
you can try Lundahl : Lundahl Transformers - Tube Amplification Output Transformers
If you check out the configuration for each given example, it must be possible to rewire for 32 ohm iso 16 ohm.
Or contact them for a solution....
“Information is not knowledge Knowledge is not wisdom
Wisdom is not truth Truth is not beauty Beauty is not love Love is not music Music is THE BEST”
Old 21st November 2012, 11:02 AM   #4
DF96 is offline DF96  England
If you have plenty of money you could ask Sowter.
Old 21st November 2012, 12:29 PM   #5
Vinylsavor's Avatar
Hi!
Those impedance numbers are no hard specs. Not for the transformer and especially not for the speaker. You might be very well off with a suitable transformer with a secondary for 16 Ohm speakers.
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 21st November 2012, 12:35 PM   #6
tyor is offline tyor  Norway
A old tube guru told me that i only have to look at the relationship between the primary and secondary.
A trafor that is used for 1k pri 16ohm sek will give 2k pri if conectet to a 32ohm speaker.
Old 21st November 2012, 12:46 PM   #7
Vinylsavor's Avatar
Hi Tyor,
also the primary inductance should be considered. If the primary inductance of your example is high enough to give the desired low frequency corner when used as 2k load, then it is ok.
Thomas
Old 27th November 2012, 10:29 PM   #8
i sent emails to some companies which make transformers yet no one send me a reply , but while i was searching i came a cross to Hammond single ended Transformer the 125GSE which gives a 25watt 32ohm at 10kohm (the primary is in range between 2.5k to 10k) , my question is , if i make dual output transformers amp that each transformer has a single 6l6 up to 20watt and the output of 16ohm on each transformer connected in series whats that going to effect on the power of two 6l6 that present a 40watt total?
the link below is for the schematic of the transformer:
Hammond Mfg. - Universal - Single Ended - Tube Output Transformers - (125 Series)
Old 27th November 2012, 10:40 PM   #9
Hello!
I can wind any SET OPT transformer you could dream of. If you would prefer something trully exotic, there is a quad of top quality iron pieces in double c core configuration, suitable for your app. This is my last set of cores (0.1mm ribbon thickness) and it will be several months before my next order. If interested, send me a PM.
Peter
Old 28th November 2012, 01:58 AM   #10
Originally Posted by petavgeris View Post
Hello!
Peter
thanx , what i'm looking for is that the transformer has a 50 watt and above 0.2 a current , the idea is to have three 6l6 in parallel 300v on plate primary of the transformer 6000 ohm to produce 15 watt , so you have 3 6l6 that give you 45 watt total but the current total will be if i'm not wrong 0.15a , and two output of 32 ohm at 6000 ohm pri , and 16ohm at 6000 ohm pri , can you wind that?
Single Ended Output Transformer mensur Tubes / Valves 1 24th August 2016 03:50 AM
Output Transformer; Push Pull to Single Ended? searon386 Parts 3 10th August 2011 11:41 PM
Driving differential ADC with single-ended source suzyj Digital Line Level 9 19th May 2009 08:39 PM
Single ended transformer grounding question Captn Dave Tubes / Valves 1 29th January 2009 06:41 PM
The ultimate single ended class a transistor transformer?! dave_gerecke Solid State 3 8th March 2008 12:00 PM
Copyright ©1999-2017 diyAudio
