6021w - Page 2 - diyAudio
Old 18th December 2008, 10:11 PM   #11
RE 604 is offline RE 604  Germany
RE 604's Avatar
Hello ,
my whole preamp - project is now here :
http://www.ak-tubes.de/Vorverstaerke...ube_preamp.htm
Regards , Alexander .
No reason to get excited : Jimi Hendrix .
Old 19th December 2008, 09:58 AM   #12
coresta is offline coresta  France
coresta's Avatar
Hallo RE604 Would you have some sockets left ? I'm building such a micropreamp ... I don't like the direct soldering of the toobz
Old 19th December 2008, 10:18 AM   #13
stoolpigeon's Avatar
RE 604, can you tell me about the gain of your 6111 line stage?
I ask because a friend gave me an Audionote Zero which uses a 6111 and has the most enormous gain. In a normal type of system with cd input the volume control barely goes past 9 o'clock and is almost unuseable.
I also believe the Quad preamp (QC?) uses a 6111 and may have been designed by the same person - Andy Groves (?) who I recall did some of the World Audio Design kit amps.
thanks, sp
Old 10th April 2009, 04:56 PM   #14
Default correct
yes, I am a bit of a student of andy grove, he did the
audionote zero preamp, and phonostage,
and the quad preamp, but tim de para did the quad phonostage.
he did afaik, 3 valve preamps for world audio
the first one used ecc88s with a gain of around 4 but it used feedback around a single tridoe stage for the line amp.
(There was also a non phono version (line only) which simply used an ecc88 cathode follower, no voltage gain.)
the second used a ecc88 again I think, transformer loaded to give a lowish gain.
and the final one used 2 cascaded ecc82s with a transformer again giving a lowish gain.
I would be VERy interested in obtaining schematics for the audionote zeros, and the quad pre's.
or if you have it, VERY good close in photos would be gratefully appreciated, so I can identify the anode and cathode resistor values
I would really like it if you could do that for me
just info for you, best wihses
Old 10th April 2009, 06:34 PM   #15
coresta's Avatar
With some 5639 and 5840 ... almost ready ... my Marantz Model 8 Bambino
Copyright 1999-2017 diyAudio
