Need help to ID a tube...
Old 17th November 2012, 11:01 PM   #1
ethanbriz is offline ethanbriz  United States
Default Need help to ID a tube...
Hi guys. I came across this nice Perryman single mesh plate power output tube. It has a nice ceramic base. I made an assumption that this was a 45 (or 245, ect), and tried to test on my Hickok 539B. The 2.5V voltage was too low to heat the filament. So, I then assumed it was a 50 (or 250, 350, etc), which uses 7.5V setting. The filament heated right up. I tested for shorts, and got one on setting A, which is expected for a 50 tube. So, at this point I assumed I had figured it out. But, when I pressed the P4 button, The "fuse" light lit up. So, obviously this isn't a 50. Any ideas? I know it isn't a good idea to try to use trial and error on a tube tester, but I was pretty sure of myself... I guess I'm not the expert I thought I was!
Old 17th November 2012, 11:05 PM   #2
[IMG]Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.[/IMG]
Old 17th November 2012, 11:09 PM   #3
astouffer is offline astouffer  United States
astouffer's Avatar
Wow, never even heard of that company before. Should be easy enough to see where the grid and plate pins go.
Old 18th November 2012, 07:30 AM   #4
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
It looks like it could be a 210T.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 18th November 2012, 03:33 PM   #5
The 45, 50 and 10 (210) all use the same settings on the 539B (ER32000). The only difference is the filament voltage and bias voltage. Both the 50 and 10 use 7.5 filament voltage. I'm guessing that since the fuse indicator lit up, that the ER32000 setting is not correct for this particular tube? Or, perhaps it is correct, and something is wrong with the tube that isn't being picked up when I rotate the short dial through the various positions?
Strange stuff....
Old 18th November 2012, 03:35 PM   #6
Palustris is offline Palustris  United States
Palustris's Avatar
"It looks like it could be a 210T"
Good call. I would love to have a pair of those.
Old 18th November 2012, 03:51 PM   #7
mctavish is online now mctavish  Austria
I dont see any grid support rods or even a grid for that matter. I am gonna bet its one of those big ol' halfwave rectifiers with a 7.5v filament, the 81. I have seen a few with mesh plates.
Old 18th November 2012, 04:08 PM   #8
You sir, are correct. Thanks for the help!
Old 18th November 2012, 04:18 PM   #9
With pleasure!
Need help to ID a tube...Hide this!Advertise here!
Tube ID help please. tropicalmuz Tubes / Valves 6 20th September 2012 11:26 AM
Tube ID Tgasboy Tubes / Valves 5 30th August 2012 06:14 AM
Help with some tube ID Scrounger Tubes / Valves 3 23rd May 2012 10:13 AM
Need help with tube ID. abmacomber Tubes / Valves 5 22nd March 2010 12:27 PM
Tube ID anyone? ectobia Tubes / Valves 2 25th February 2008 02:33 AM
