Old 17th November 2012, 12:26 PM   #1
mississippi's Avatar
Default Power and output transformer separated from amplifier
Are there problems to expect when the output tranformers are mounted in another box, about 1 meter away from the amplifier(s)?
Old 17th November 2012, 01:55 PM   #2
TheGimp is offline TheGimp  United States
TheGimp's Avatar
You will be subject to radiated noise susceptance. However, considering the voltage levels in the primary of an OPT, I doubt it will be noticeable unless you live in a high EMI/RFI environment. You could shield the cable assembly with braid to minimize it.
Safety wise, you are going to be carrying HV through the connecting cable so due diligence is in order. The shield would be a good idea from this prospective as well.
Old 18th November 2012, 07:59 AM   #3
Thanks,
I was also worried about the frequency range of the amplifier, because a shielded cable has a capacitance to ground and a small induction from the cable.
Is there somebody who can simulate this what happens with the bandwith?
bridgin 2 channel amplifier with output transformer:Mcintosh style muddasirwaheedmalik Solid State 5 25th May 2012 12:05 PM
Aikido as a headphone amplifier (Output transformer groupbuy) Bas Horneman Headphone Systems 63 1st March 2012 04:58 PM
power transformer as output transformer seedseed Analogue Source 18 7th May 2011 06:52 PM
Car amplifier output transformer rem280 Solid State 1 11th November 2009 10:23 AM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
