heater wiring question
I have a transformer with two 6.3V 4A windings.
The four power tube heaters are 12.6V 1.8A total.
The rectifer tube is 6.3V 1.6A.
The preamp/phase splitter tube heaters are 6.3V 0.9A total.
Can I wire it like this?
If so, is there a best way to obtain a ground reference for the preamp tubes?
I'm not sure the power tubes need a ground reference but can that be done also?
Thanks,
Scott
That's great, thanks. Yes, the rectifier is a 6BY5GA with isolated heater. If I understand correctly, I can just create a standard virtual center tap on only the preamp/PS supply with a 100R from each leg of the supply to ground?
I was concerned about that since that also ties the center tap junction of the 2 6.3V supply windings to ground through one of the 100R.
Thanks,
Scott
