Space-charge tetrodes in Inverted Mode
Old 17th November 2012, 08:20 PM   #11
zesak is offline zesak
That is the thing. I do not feel like melting anything but I do not have the max grid power allowed info to limit the current if needed.
Is it inherently safe from melting when all tube terminals operate with maximum of 24V on them, or do I still need to insert current limiting resistor ?
Old 18th November 2012, 06:15 PM   #12
Before I start melting grids I decided to try to simulate the circuit with LTspice using 12K5. I found a model that might work here on diyaudio but I do not yet know how to associate drawing of a tetrode with its correct model so that I do not get a message "model not found" or "library not found" when I try to run the simulation. Does anyone know an easiest step-by-step method to do that, or can you provide a link that shows the steps required in LTspice ? Thank you so much !
Space-charge tetrodes in Inverted ModeHide this!Advertise here!
Using a standard pentode-tetrode as output "space-charge tube" any ideas-experiences? bembel Tubes / Valves 12 11th March 2010 06:56 AM
space charge 12fx8 amp or preamp schematic? Bob_345 Tubes / Valves 13 22nd January 2010 04:46 AM
VBIGC in non inverted mode ebijma Chip Amps 3 7th March 2004 11:17 AM
low voltage tubes (space charge, etc.) for guitar amp? needtubes Instruments and Amps 4 31st October 2003 01:45 AM
Copyright ©1999-2017 diyAudio
