choosing input valve - Page 2 - diyAudio
Old 15th November 2012, 08:33 AM   #11
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
Originally Posted by DF96 View Post
Better to have valves and circuits which add nothing. 'Personality' is fine in a guitar amp but undesirable in a music reproduction system.
Then why use valves at all? A transistor amp will have less colour at a fraction of the cost...
Old 15th November 2012, 08:55 AM   #12
SY's Avatar
Why drive a '57 T-Bird? A new Honda will get you to the same place at a fraction of the cost.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 15th November 2012, 08:58 AM   #13
Vinylsavor's Avatar
Hi!
You should select the input tube based on the requirements it has to full fill in terms of gain and driver capability. This heavily depends on the overall circuit. I agree with previous posters about 12AX7 or similar not beeing the best suited to drive an output tube.
Lower rp tubes unfortunately often have too low mu. I found the 6N7 (both halves paralleled) a good compromise. Considerable gain at reasonably low rp for small output tubes
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 15th November 2012, 09:06 AM   #14
DF96 is offline DF96  England
In my case it is a combination of nostalgia, and finding that my attempt at designing and making a solid-state power amp failed due to both output oscillation and loop oscillation. Used properly, valves can do as good a job as SS - in the sense that the music is not noticeably damaged.
I have little sympathy for those who strain for 0.001% THD using SS, or for those who seem happy with 10% THD using valves. Both seem to miss the point.
Old 15th November 2012, 10:06 AM   #15
My main reason for me wanting a single ended amp is because I once owned a Fatman 182, though it proved unreliable in the end, the sound was superb. Even my wife enjoyed it, she said it was like listening to a favourite cd for the first time. It had KT88 output valves and I think 6NP1 triodes. I want something that will sound as good but using a readily available triode here in the UK.
Old 15th November 2012, 10:27 AM   #16
Merlinb's Avatar
Actually that supports my argument, rather than countering it.
If absolute fidelity is your goal (e.g., a fast efficient car), why use valves (e.g., T-Bird)? Answer: fidelity has surprisingly little to do with enjoyment...
Old 15th November 2012, 10:33 AM   #17
Go for one octal pretube per channel.
That gives you the option to play with 2-stage/parallel/1-stage+CF without having to hacksaw the chassi.
For the rest you need first to decide on what you need, mostly depending on your speakers and listening habits.
Old 15th November 2012, 10:38 AM   #18
I converted the ferrari to model T in my setup by resistor loading the mosfets .
4P1L driver and resistor loaded mosfets for output.
Makes any other tube amp look like energyclass A+ .
Old 16th November 2012, 02:13 AM   #19
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by DavesNotHere View Post
just build an amp to where they have both sockets and a/b it.
+1
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 16th November 2012, 02:22 AM   #20
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
When going to absolute fidelity I prefer to combine tubes with SS devices.
Such marriage produces the best results.
The Devil is not so terrible as his math model is!
LEDs on input valve cathodes woodturner-fran Tubes / Valves 12 29th February 2012 01:27 AM
Valve cascodes for Phono input. velvetsunrise Tubes / Valves 8 17th June 2011 07:28 PM
any advice on how to match a headphone level output to valve amp input levels? mondogenerator Headphone Systems 1 18th December 2009 03:08 AM
Choosing Valve kmj Tubes / Valves 8 26th January 2006 03:36 PM
Copyright 1999-2017 diyAudio
