#11 |
I'm pretty new to DIY, so wasn't comfortable handling high voltage kits at this point. So I selected this kit together with the amp camp kit for my amplification. I'll get more adventurous as my knowledge of electronics increases...
#12 |
I'm very curious what the sonic differences would be, and what the advantage of high voltage is. I don't know much about this stuff but it's interesting that you can go from hundreds of volts down to tens of volts and still make a similar component work in a similar circuit; it implies there's a wide range of what could work and probably certain qualities that would result from the differences...
#13 | |
There are tubes designed for low voltages.
Hello |
| Glass-ware.com DIY goodies by Broski | specialidiot | Swap Meet | 2 | 23rd November 2011 10:49 AM |
| I forgot what soft ware I used can someone help please? | Boscoe | Software Tools | 3 | 22nd May 2010 07:00 AM |
| SRPP+ from Glass Ware needs some help please | audioguy67 | Analog Line Level | 1 | 7th February 2010 10:52 PM |
| Tube Cad from Glass-Ware questions | Tyimo | Tubes / Valves | 2 | 28th December 2007 02:07 PM |
| what glass-ware program? | jarthel | Tubes / Valves | 1 | 27th October 2006 09:38 AM |
