Old 13th November 2012, 01:54 AM   #1
Bengali is offline Bengali  United States
Default OD3 150V tube regulator
Do you know if the OD3 150V Tube reg. are prone to be noisy?
I built up a Foreplay III clone and getting hum. I never use the OD3 before.
I measure +150VDC at the output of the OD3 so it's working.
Non regulated DC heater with 10,000uF cap, +5.95VDC. Heater voltage is low but not the cause of the hum.
Old 13th November 2012, 10:08 AM   #2
DF96 is offline DF96  England
All gas regulators can be a bit noisy. Unlikely to cause hum. Hum is usually caused by construction techniques, such as poor grounding or coupling between bits of the circuit which should not be coupled.
Old 13th November 2012, 04:11 PM   #3
kevinkr's Avatar
Post some pictures and a hand drawn schematic of the power supply and pre-amp circuit. Do this will allow people to advise on potential build and design issues.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 13th November 2012, 06:28 PM   #4
12E1 is offline 12E1  United Kingdom
12E1's Avatar
One exception - if there is added capacitance across the regulator tube it can make a fine oscillator. Not saying this is the case, but one to watch out for.
As kevinkr has suggested, any circuit or info that you can provide would be helpful in diagnosis.
Getting down to a regulated 150V AudioFox Power Supplies 17 11th January 2011 11:01 AM
150v Mosfet @ 146v? theAnonymous1 Class D 12 16th December 2008 02:57 AM
OD3/OA3 voltage regulation design Carlp Tubes / Valves 1 21st February 2008 05:57 AM
WTS: NOS CBS-HYTRON OD3 Tubes VR150 Richardgreat Swap Meet 0 3rd September 2007 08:32 PM
Solid state amp on +/-150V ? DJG Solid State 1 12th March 2003 08:46 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
