Old 12th November 2012, 02:55 PM   #1
wicked1 is offline wicked1  United States
wicked1's Avatar
Default Tube Frequency Response
I've just received a bunch of 12sn7's to retube my aikido phono amp. They're what I think are called coin base. These new ones are JAN tubes. I replaced some RCA tubes which appear to have the exact same construction. Same plates, same heaters, same mica supports, etc.
BUT..... these new tubes do not have bass! It's not subtle. It's like a filter has been put on my system. They get down to the kick drum level, but none of the rumbly low bass, or decay on bass notes, etc are there.
I put the old tubes back in, and it sounds good again. Other than the distortion when I turn it up... (Old tubes are several years old.. Volume knob needs to be up at 75%. New tubes, volume needs to be at about 25% for the same loudness, and there is no noticeable distortion)
I don't understand what happened to the bass, though! I wouldn't think there would be such a large variation in the frequency response in the tubes.
Old 12th November 2012, 03:16 PM   #2
DF96 is online now DF96  England
As all valves work down to DC the most likely change is an increase in treble which is then interpreted as a reduction in bass. However, in some RIAA amps the exact network response can be affected by the valve anode impedance, which can increase with age as the transconductance reduces. Other things being equal, it is more likely that the new valves give the correct response but you had become used to the old sound. This assumes that the network values were carefully calculated and not, as some seem to do, adjusted 'by ear'.
Old 12th November 2012, 03:24 PM   #3
wicked1's Avatar
Thanks! that was my assumption as well. I'm listening to the old tubes now, and there is definitely less information in the highs.
My riaa resistors and caps were calculated based on my tubes via a formula in the aikido phono instructions. I'm tempted to adjust them by ear now, but I should probably let my ears re-adjust, instead.
-I guess if it keeps bothering me I could easily change the loading on the input to my phono amp, to roll off the highs a little.
Old 12th November 2012, 03:34 PM   #4
Double-check your calculations, just in case you made a mistake. Apart from that, I think you should give it a while and see if your ears get used to it, as you say.
Old 12th November 2012, 04:01 PM   #5
Vinylsavor's Avatar
Hi!
You should check the frequency response with a signal generator and a scope. Only then you really know what's going on and what to change if necessary. For phonostages i recommend to measure the linearity of the circuit by removing the RIAA components. Replace it with a 1:10 voltage divider to avoid overload.
If the gain stages work linear, then add the RIAA circuit again and check it with a iRIAA network at the input
If you don't have a scope, borrow one or get a used one
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 12th November 2012, 04:44 PM   #6
kevinkr's Avatar
Do you have tube tester? I would check to see whether the transconductance of these new tubes is in the expected range as a way of verifying that they are actually 12SN7.
Another thought would be to build a simple amplifier circuit and measure the gain.
Good 6SN7/12SN7 should last for a very long time at moderate currents - I've had to replace very few.
As a quick simple check measure the frequency response of the phono stage with original tubes and then the new ones. Gain at 20Hz should be approximately 20dB higher than at 1kHz, also measure at 20kHz and verify the gain is about 20dB less than at 1kHz. ** An easy way to do this with a scope would be to set it up at 1kHz for 200mVpp output, at 20Hz you would than have approximately 2Vpp, and at 20kHz 20mVpp - this should be within the range of accuracy of your scope and eyes. All of this presupposes you have a decent scope and sine wave generator. Set the scope so that 4 vertical divisions are used for each amplitude measurement, do not adjust the generator once set.
Note:
** These are approximate values, refer to the RIAA curve for the exact numbers, but with a scope the resolution is insufficient to make this level of accuracy necessary.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 12th November 2012, 04:52 PM   #7
ruffrecords's Avatar
There is something funny going on here. There should not be a three to one variation in apparent gain between tubes of the same type. It sounds to me like you used to have 6SN7 tubes in there and you have replaced them with 12SN7 types so the heaters are being severely under run. If it is not that then the tubes you have been sold are suspect.
Cheers
Ian
Ian
Old 12th November 2012, 05:30 PM   #8
tubelab.com's Avatar
Are they JAN Sylvania or Philips ECG (green or blue ink)? These guys were notorious for stuffing the envelope with whatever guts they had to fulfill whatever contract they were bound by at the end of the vacuum tube era. The tube was tested to work in whatever equipment that the contract stated, but often bore no similarity to the type number stamped on the glass. This was not an issue until the tubes appeared on the surplus market.
There are some 6BG6GA's that actually contain 7027A guts. These are good for far more power than a 6BG6 could ever make. There are some 6B4G's (a DHT) that contain 6AV5 guts (a an indirectly heated sweep tube pentode). I have seen two different "6CW5's" that contained unusual guts. Both melted quickly in a Tubelab SPP amp that uses 6CW5's.
Your tubes could contain a mismatched set of components that may not have a Mu near 20, but may have worked OK in whatever military equimpent specified in the contract.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 13th November 2012, 01:25 PM   #9
wicked1's Avatar
Thanks everyone.. KevKR, those are good instructions for testing. I have a very old scope and an analog modular synthesizer. I believe those will do. The scope isn't exactly calibrated, but as you said, it should be good enough to see the difference.
I know they're 12sn7's and replacing 12sn7's. There is actually one pair of 12sl7's in the mix, but I haven't replaced those yet. (Aikido.. 8 tubes for the phono amp alone!)
And Tubelab, they are green ink. Date stamp says 87, so definitely beyond the end of the vacuum tube era.
I also have a 12sn7 preamp in my basement, so I put these tubes in there... They were light on bass there too. Not quite as bad, but that's only one gain stage, vs the two in the phono. I'm also beginning to doubt post #2 and 3, saying maybe there is just more treble now. There is some more, but unfortunately the bass issue is like a relatively sharp filter. I turned up my subwoofers, but there is simply nothing there for them to amplify!
Well, I didn't want to get quite this deep in to the project, but I think you are all on the right track, and the only way to proceed w/out driving myself crazy is to use some test equipment.
(or just buy a different batch of 12sn7's I'm pretty confident at this point, that it is the tubes. Buying tubes on ebay is like going to vegas)
in-room frequency response & transient response MCPete Multi-Way 1 8th October 2011 06:31 AM
Frequency response 2litre Analog Line Level 5 31st May 2006 07:00 PM
frequency response pmarcouxx Digital Source 2 20th July 2005 07:43 PM
Frequency Response - Is this good ?? mark.carline Multi-Way 26 22nd April 2004 11:18 PM
Doubts on Phase Response and Frequency Response dumrum Multi-Way 11 5th April 2004 10:39 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
