Big B+ voltage drop using diode rectifier.
Old 13th November 2012, 05:09 PM   #21
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Get rid of the RC and just run a CLC. This will minimize your DC losses.
Use a large C2 value (330uF) and adjust the first cap value to set your B+.
Old 13th November 2012, 09:23 PM   #22
tomchr is offline tomchr  Canada
tomchr's Avatar
If PSUD won't dance for you, PSpice, LTspice or regular spice will.
Just place two inductors, L1 and L2 along with a 'K' spice directive: K1 L1 L2 0.999
This makes a transformer with a coupling coefficient between primary and secondary of 0.999 (99.9 %).
Include the DCR of all the components - including both the primary DCR and secondary DCR of the transformer.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 14th November 2012, 08:46 AM   #23
vingenz is offline vingenz  Italy
It's better PSU then LTspice for transformers....i think
Old 14th November 2012, 03:45 PM   #24
DavesNotHere is offline DavesNotHere  United States
Originally Posted by vingenz View Post
Hello folks!
I've built an amp with 2x6l6gc P-P AB1 in the power section. There is problem that I can't solve: after full wave rectifier, B+ is 460VDC (372VAC on secondary) at idle, and 395VDC (350VAC on sec.) at full power.
Power transformer specs are: 250mA; 372-0-372VAC.
6l6 are biased (fixed bias) at 35mA each. Diodes are 1n5408 (1000v, 3A)
Well, i need more clean headroom and I can't understand why it's sagging too much . Suggestion? Tricks?
Thanks!
well the best thing is to increase regulation. about another 100Uf or so in the power supply would work nicely. but regardless of how stiff you make the power supply, it supposed to sag slightly without inducing power supply noise.
like this power supply : this is for 4 6l6's and 4 12ax7's the 2H choke was deleted in final design that mesa boogie uses.
Copyrighted schematic deleted by Moderation
Old 14th November 2012, 03:58 PM   #25
If you really want to increase headroom in the amp. Make the B+ hotter like 480-500V to the plate. But this path should be left for the ones who are not afraid of pushing the envelope. And making sure they adjust the bias when upping the plate voltage.
Old 14th November 2012, 04:14 PM   #26
and I encourage use of the series caps with bleed resistors as this safely discharges the circuit when the unit is turned off.
Old 14th November 2012, 06:04 PM   #27
How?
Old 15th November 2012, 02:10 AM   #28
Sorry, moderator deleted my schematic. I'll have to make one instead of posting my originals ( even though they settled on a different design).
O.k. with using public domain knowledge, we'll walk you through the designing phase. So give me a few minutes as I will have to setup some sort of flicker accoun
Old 15th November 2012, 02:21 AM   #29
Enzo is offline Enzo  United States
Several people suggested it, did you provide us the DC resistance of the power transformer windings? From your report, your AC voltage at the transformer was dropping considerably. If that voltage drops, then so will the resultinbg rectified and filtered DC. You can consider the resistance of the winding to be in series with it and causing voltage drop with current flow.
Old 15th November 2012, 02:26 AM   #30
tomchr's Avatar
You also need to consider the resistance of the primary. The total resistance that should be considered to be in series with the secondary winding is:
Rtotal = Rprimary*(Vsecondary/Vprimary)^2 + Rsecondary
~Tom
Big B+ voltage drop using diode rectifier.Hide this!Advertise here!
rectifier voltage drop dsavitsk Power Supplies 21 25th November 2015 06:01 PM
Toroid transformer and big voltage drop Fredde79 Power Supplies 5 27th June 2012 08:56 AM
need to clear about voltage of diode rectifier for psu mdm102 Power Supplies 2 17th July 2010 10:17 AM
Rectifier voltage drop question jrenkin Tubes / Valves 2 7th March 2010 09:39 PM
Voltage drop AZ1 = AZ11 = RGN1064 rectifier tube Klimon Tubes / Valves 2 29th June 2005 11:19 AM
Copyright ©1999-2017 diyAudio
