6AU6 replacement - Page 9 - diyAudio
Old 26th November 2012, 05:54 PM   #81
DF96 is offline DF96  England
Screening is placing a grounded conductor in the way. That stops an electric field.
Mains transformers often hum a bit. Mount on rubber washers, but ensure you have a ground connection to the transformer frame.
Old 26th November 2012, 08:25 PM   #82
pancaQe is offline pancaQe  United States
pancaQe's Avatar
I've never heard of that. So just running a conductor that attatached to ground in between a heater line and a signal line will block the field?
This is the first amp of this size I've built, everything else has been SE 6BM8 or 6BQ5 amps. So I'm not used to a transformer of this size. It hums and buzzes.
Old 26th November 2012, 08:45 PM   #83
vinylkid58's Avatar
Does it get hot too? Sounds like it's time for a new one.
jeff
Old 26th November 2012, 08:52 PM   #84
AC heater wires can cause hum problems from both electric and magnetic fields. Twisting reduces the magnetic field.
The electric field can be reduced by running the wires in the corner of the chassis. This is because, to a limited extent, putting a grounded conductor behind can reduce the field. (See 'method of images' method for determining the field from a charge near an equipotential plane.) A screen all round is much better of course.
Old 26th November 2012, 08:59 PM   #85
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
what do you mean by screening?
Screening = Shielding.
Radiator = Heatsink.
Anode = Plate.
The Devil is not so terrible as his math model is!
Old 26th November 2012, 09:08 PM   #86
Thanks. For us Brits a shield is something a soldier used to carry to protect him from sword blows. I know what others mean by a shield, but I forget that they might not know what I mean by a screen.
Old 27th November 2012, 06:32 AM   #87
dgta is offline dgta  United States
And bloody or bleeding does not necessarily involve hemorrhaging
6au6 for stereo? TechnoBeaver Tubes / Valves 5 9th April 2010 03:11 PM
6AU6 pentodes TGRANT Tubes / Valves 20 6th March 2009 12:22 AM
6au6 Cf mashaffer Tubes / Valves 3 21st April 2008 10:19 AM
better 6au6 alternative nhuwar Tubes / Valves 6 6th February 2007 06:10 PM
6AU6 Varieties wrenchone Tubes / Valves 2 13th January 2007 10:49 PM
Copyright 1999-2017 diyAudio
