6AU6 replacement
6AU6 replacement
Old 18th November 2012, 11:30 PM   #61
vinylkid58 is online now vinylkid58  Canada
vinylkid58's Avatar
Originally Posted by pancaQe View Post
Actually this will be a pair of mono-blocks.
If you're trying to economize, why not go with a single chassis amp?
I like the schem you showed earlier, but was put off by the filter chokes.
You could build it without the chokes, but they're there for a reason. Personally, I'd use one in a CLC config., but your PS trans should be no more the 300vAC, otherwise you're going to end up with way too much B+.
And it doesn't look complex, compared to a couple other designs I've built it actually looked fairly simple.
As Kevin points out, the Williamson has issues, and could result in an exercise in frustration. 6V6's are easy to drive with a concertina, and you can get away with cheaper OPT's.
What circuit were the other amps you built based on?
jeff
Old 19th November 2012, 12:33 AM   #62
pancaQe is offline pancaQe  United States
pancaQe's Avatar
[QUOTE=vinylkid58;3246929]If you're trying to economize, why not go with a single chassis amp?
Good point, Vanity, I've always wanted a mono-block pair and there seems to be some advantages I'm curious to explore.
My power xfrmr is 350vAC
The first amp I built was the little 6BM8 SE, 3watt stereo below
And then the 6AQ5 SE below
Also just finished the 12AT7 audio generator
Old 19th November 2012, 03:43 AM   #63
vinylkid58's Avatar
Yes, it usually involves space for more iron, hence a better power supply for each amp.
That's really 6L6 territory.
Which one sounds better?
jeff
Old 19th November 2012, 07:26 AM   #64
pancaQe's Avatar
The ps transformers came out of a couple of weird Moviola mdl#565. I have no idea what they were for but they had 1-5Y3, 2-6V6, 2-6J5, 1-5879, 1-OC3. A couple of 1/4" jacks labeled "OPT" and "MAG". So I figured they would be good for a 6V6 amp.
I liked the 6BM8 3-watt (which I just realized I posted the wrong schem, correct one below). I'm no audiophile and I've been doing living sound engineering for so long my hearing probably wouldn't pickup most of the anomalies talked about on this forum. But both amps seemed to be thin, lacking in low end 200hz and below maybe. And just not very loud. I listen to rock n roll and so a little volume is desirable.
Old 19th November 2012, 08:43 AM   #65
EssB is offline EssB  United Kingdom
FYI: "OPT" and "MAG" refers to Optical and Magnetic sound pickup heads on film projectors. The preamps may have some eq networks to give the correct academy response curves, that might be causing the thin sound.
Old 19th November 2012, 09:17 AM   #66
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Why don't you just stick with your original idea ? Buy 2 7-pin sockets that fit into a 9-pin sockethole and you are done. If you don't like the result change it into something else. In the mean time try this design to change your 6BM8 amp. I tried it and it sounds really good.
Old 19th November 2012, 10:30 AM   #67
pancaQe's Avatar
@EssB: I didn't use anything but the power transformers from the Moviola chassis. I was just describing what I pulled the trannys out of in hopes that somebody knew what they were purely out of curiousity. thanks though
@Jaap: I've decided to save my stock of 6AU6 tubes for another build. I really want to find a design using 6SN7's and 6V6's. Thanks for the the upgrade, I think that's just what I need cause I really want to get to work on something.
Old 19th November 2012, 11:04 AM   #68
Jaap's Avatar
You can exchange the 12au7 for the 6SN7 without any problem, at least that is what I am going to do in the near future (with CCS and led on first tube). I prefer local feedback in all cases to global feedback, that is one reason why I want to try this design.
In a RCA handbook I saw that you can also scale this design up with parallel 6V6 in het outputstage and get 20 Watts from it.
Old 19th November 2012, 11:50 AM   #69
pancaQe's Avatar
Are you talking about the schematic below?
With the CCS, are you going to use the LED's voltage drop to derive the constant voltage for the CCS? What about using an LM317 regulator.
I posted a schema for what was identified as a Williamson type design with 2-6sl7 and 2-6v6. But I was informed it was not a good choice. So I'm still looking
Old 19th November 2012, 12:23 PM   #70
Jaap's Avatar
Just use the 6SN7 where you had 12au7 in your original RCA-design. Take other component values, for instance from post 56. If it works you can try to use a (v)ccs on top of the first tube and a led for the cathode resistor. You can find a lot of info on this forum.
6AU6 replacementHide this!Advertise here!
6au6 for stereo? TechnoBeaver Tubes / Valves 5 9th April 2010 04:11 PM
6AU6 pentodes TGRANT Tubes / Valves 20 6th March 2009 01:22 AM
6au6 Cf mashaffer Tubes / Valves 3 21st April 2008 11:19 AM
better 6au6 alternative nhuwar Tubes / Valves 6 6th February 2007 07:10 PM
6AU6 Varieties wrenchone Tubes / Valves 2 13th January 2007 11:49 PM
