6AU6 replacement - Page 6 - diyAudio
Old 14th November 2012, 05:34 PM   #51
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Originally Posted by DF96 View Post
He asked for rectifier subs?
simply try what you have and see what it brings (after you have checked the specs)
Old 18th November 2012, 06:14 AM   #52
pancaQe is offline pancaQe  United States
pancaQe's Avatar
I've decided to go with this design. Any suggestions on improvements?
Click the image to open in full size.[/IMG]
Old 18th November 2012, 05:39 PM   #53
vinylkid58's Avatar
Don't see an image?
jeff
Old 18th November 2012, 05:43 PM   #54
Loose the 80mfd cap after the rectifier and go with a reasonable sized cap for one.
Old 18th November 2012, 07:08 PM   #55
pancaQe's Avatar
Yea I can't seem to figure out if I can post an image that's on my computer, or does it have to be a URL.
Old 18th November 2012, 07:15 PM   #56
pancaQe's Avatar
I figured I'd look at the site FAQ to see about posting images, low and behold there it was so here it is.
Old 18th November 2012, 09:22 PM   #57
kevinkr's Avatar
This is essentially the Williamson circuit which has way more gain than required for use with the 6V6 even with pretty significant levels of global feedback applied. It also frequently exhibits LF instability that is almost impossible to eliminate if you do not have profound understanding of loop stability criteria and the equipment required to measure the open loop phase shift and gain.. (Think Bode plot here)
A variation of the Mullard 5-20 circuit with a high mu triode like the 6SL7 in the front end might be a better (sounding) choice. Gain while still high may be made more in keeping with modern sources like CD players and DACs..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 18th November 2012, 09:33 PM   #58
pancaQe's Avatar
Thanks kevinkr. I never thought it would be so difficult choosing a good design using the tubes I have available. I'll check out the Mullard 5-20.
Old 18th November 2012, 09:38 PM   #59
vinylkid58's Avatar
Why?
Needlessly complex with a mediocre power supply. You're building a "mono" amp right, not a pair of mono-blocks for stereo? I like the schem. I posted earlier way better, I'd just change the PS a little.
jeff
Old 18th November 2012, 10:06 PM   #60
pancaQe's Avatar
vinylkid, Actually this will be a pair of mono-blocks. I could tell the ps was weak and was looking into beefier alternatives. I like the schem you showed earlier, but was put off by the filter chokes. I'm trying to build this with parts on hand. Kind of a garage junk build with a sound of gold . And it doesn't look complex, compared to a couple other designs I've built it actually looked fairly simple.
6au6 for stereo? TechnoBeaver Tubes / Valves 5 9th April 2010 03:11 PM
6AU6 pentodes TGRANT Tubes / Valves 20 6th March 2009 12:22 AM
6au6 Cf mashaffer Tubes / Valves 3 21st April 2008 10:19 AM
better 6au6 alternative nhuwar Tubes / Valves 6 6th February 2007 06:10 PM
6AU6 Varieties wrenchone Tubes / Valves 2 13th January 2007 10:49 PM
Copyright 1999-2017 diyAudio
