Old 12th November 2012, 12:26 PM   #21
Tony is offline Tony  Philippines
Tony's Avatar
Originally Posted by pancaQe View Post
Can anyone suggest a simple, quality 6V6 push pull amp design/schematic. At this point it looks like I'm gonna have to back track anyway. I'm looking at schematics using 6SN7. Any suggestions?
why not a 6LU8 pp amp instead, at a dollar each, U$4 buys you a quad of output power tube, i made 2 amps based on this and i can definitely say that it is worth it...
Old 12th November 2012, 12:28 PM   #22
Tony's Avatar
Originally Posted by SY View Post
But ultimate origin? Not RCA, I think. The input stage is a poor version of the Williamson (there must be almost 0.3mA going though the cathodyne!), the feedback arrangement is relatively ineffective, and RCA engineers were smart enough to understand feedback from the OPT secondary.
RCA's actual pentode driver amp was quite an excellent and innovative design.
in later RCA tube databooks, a 50 watter 7027 design using the same topology was presented, almost since the input used a triode pentode type....
Old 12th November 2012, 12:37 PM   #23
DF96 is offline DF96  England
That 50-watter is only a 35-watter in RC-19 (1959). 7199 input and PS, 6AU6 drivers, 7027 output. On a closer look the driver is a bit different from the 10-watter.
Old 12th November 2012, 12:58 PM   #24
pancaQe is offline pancaQe  United States
pancaQe's Avatar
Tony, I have a couple GE 6LU8A, I thought they were oscillator amplifier. They're also compactron (tiny)
Old 12th November 2012, 12:59 PM   #25
SY's Avatar
Yes, that was the design I referred to in post 14, a very clever circuit. I think it used 6CB6 drivers (RC-21).
If there's a sucker born every minute, where do the rest of them come from?
Old 12th November 2012, 03:31 PM   #26
pancaQe's Avatar
Another tube I've been reading a little about is the 6AS7GA. Any thoughts on those and which tubes would work well as drivers for them.
Old 12th November 2012, 05:40 PM   #27
morinix is offline morinix  United States
Buried on this site is a 6as7 SRPP amp I built long ago. It is a good tube, BIG sound. Needs lost of voltage drive since its mu is so low.
Robert
Lounge Audio
Old 12th November 2012, 05:58 PM   #28
vinylkid58's Avatar
Here's a schem. I had sitting on my HD. The 6V6's are strapped as triodes, but you could change that.
jeff
Old 12th November 2012, 08:28 PM   #29
pancaQe's Avatar
thanks everyone for your suggestions. Vinylkid, I think that scem is the one i'm gonna use. I wanted one using the 6SN7. Thanks, I'll post how it's coming along.
Old 12th November 2012, 08:35 PM   #30
pancaQe's Avatar
Oh, I'm not familiar with what strapped triodes are. Could you explain?
thanks
6au6 for stereo? TechnoBeaver Tubes / Valves 5 9th April 2010 03:11 PM
6AU6 pentodes TGRANT Tubes / Valves 20 6th March 2009 12:22 AM
6au6 Cf mashaffer Tubes / Valves 3 21st April 2008 10:19 AM
better 6au6 alternative nhuwar Tubes / Valves 6 6th February 2007 06:10 PM
6AU6 Varieties wrenchone Tubes / Valves 2 13th January 2007 10:49 PM
Copyright ©1999-2013 diyAudio
