Worlds Most Expensive Tube Amp !!!
Old 12th November 2012, 12:05 AM   #1
spirey is offline spirey  United States
Default Worlds Most Expensive Tube Amp !!!
This would be a real DIY AUDIO challenge. How to get 20,000 clean watts?
How much 4% Silver solder did this designer use for his Amp?
Have you got about $500,000 (on sale) to spend, then this Tube Amp is for you, the soldering is on them.............
Check out the 6 feet (about 2 meters) tall and half a ton heavy monster designed by Pivetta Andrea. The amp has been built by the Italian company in his own name and will be distributed worldwide by HigherFi exclusively. The Opera One can also be attached to a surround system that has up to 12 speakers.
Happy Listening ... Ray
Old 12th November 2012, 12:29 AM   #2
badman is offline badman  United States
badman's Avatar
Wow.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 12th November 2012, 12:42 AM   #3
freax is offline freax
freax's Avatar
Yes, let me just go get my rubber cheque book.
I would hate for that thing to be amplifying in the RF range in my living room... serious RF burns are a possibility here, I do hope it has a notch filter, doesn't look like it tho it is a component of a much larger system.
Also, 2 years ago called: http://www.extravaganzi.com/pivetta-...ive-amplifier/
Ontop of that the metal shielding around the outside is seriously lacking in what I would call a faraday cage.
I bet anyone with a cellphone within a few meters of this thing could get GREAT reception!
**DIT**DIT** **DIT**DIT** **DIT**DIT**
"CAN YOU HEAR ME NOW!???!???!! YEAH CAN YOU PICK ME UP I'M AT SOME RICH GUY'S PLACE, WHAT?! YES I DO HAVE CASH"
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 12th November 2012, 01:24 AM   #4
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Originally Posted by badman View Post
Wow.
double wow.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 12th November 2012, 01:53 AM   #5
jazbo8 is offline jazbo8
jazbo8's Avatar
That's 20kW per channel
A different version here: www.onlycreative.it
Awesome Italian engineering.
Jaz
Old 12th November 2012, 02:01 AM   #6
Triodethom is offline Triodethom  United States
Triodethom's Avatar
I would guess the 150 amps at 240ac would be a start for this 12 channel 1500 watt per amplifier cluster say about the same size as most people whole house.
Old 12th November 2012, 04:59 AM   #7
Default We all Enjoy EnjoyTheMusic
Wow.
Keep up the good work.
Old 12th November 2012, 05:22 AM   #8
Discochicken is offline Discochicken  Australia
Meh. My SSE would give it a good run for it's money. LOL!
Old 12th November 2012, 05:41 AM   #9
TV7 is offline TV7  Australia
TV7's Avatar
This is the tube section so where are the tubes? seriously I want to see glowing 20,000 W! GLOWING!
First things first, but not necessarily in that order.
Old 12th November 2012, 06:43 AM   #10
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I can see rows of TO-3s on each red flanking sink. Maybe the steam punk structure in the centre is some sort of ceramic mutha tube regulated HV supply?
Worlds Most Expensive Tube Amp !!!Hide this!Advertise here!
3886 based power amp kit, how to find the best AND the less expensive PCB board? bidibidi Chip Amps 31 14th August 2011 01:12 PM
Worlds smallest HiFi valve amp fergs1 Tubes / Valves 51 17th September 2008 11:32 AM
Worlds smallest amp? Rikard Nilsson Chip Amps 18 9th September 2008 02:37 AM
Very expensive WE106A pre-amp, any member had this?? tube-lover Tubes / Valves 12 23rd September 2007 06:51 PM
Binding posts for an 8 channel amp = more expensive than the toroidals.... SkinnyBoy Parts 14 30th December 2003 04:49 AM
