Amp Cage Fababricators? - diyAudio
Old 10th November 2012, 05:01 PM   #1
heyraz is offline heyraz  United States
Default Amp Cage Fababricators?
The first amp I restored was a Dynaco ST-70 with cage. I worked on it upside down while supported by it's attached cage which rested on a heavy sheet of cardboard, enabling me to spin the entire assembly around on my workbench without scratching the cage.
Right now I'm working on a Pilot 232 Stereo Plus, but it lacks a cage. I would like to have a cage fabricated for this amp and another (Fisher 481-A. Although I may not run either amp with a cage, I would like them just the same, for service and storage.
Any suggestions and experience with private fabricators?
Old 12th November 2012, 12:32 AM   #2
tomchr is offline tomchr  Canada
tomchr's Avatar
You could always take up brazing...
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 12th November 2012, 03:39 AM   #3
I don't have a problem brazing, soldering or spot welding, but I need a brake and shear to do a classy job.
Hell, I could do it with an Erector Set if I had to.
Old 12th November 2012, 03:54 AM   #4
chrish is offline chrish  Australia
chrish's Avatar
For use it would have to be a cage, but for service and storage it could be a simple MDF or plywood box. For servicing only, a simple jig from MDF or ply works well.
Old 12th November 2012, 04:53 AM   #5
I normally service my amps propped on books in a shallow cardboard box. However, I like the idea of having a "built in" service cradle to go with an amp. Supporting the amp upside down by a ventilated cage is a little safer and more stable when measuring voltages than on books or in a closed box. I know this because I have an unventilated box but it gets pretty warm in there.
This is nothing critical-I was only wondering if anyone had the name of a fabricator and was satisfied.
Rich
FS Eico ST-40 Faceplate and tube cage jdeitch11 Swap Meet 1 14th May 2013 03:12 PM
Shielded cable or faraday cage or both? Frosteh Analog Line Level 5 3rd February 2012 02:21 PM
300b tube cage dsavitsk Tubes / Valves 15 23rd January 2010 10:29 PM
Tube Cage Question SRMcGee Tubes / Valves 8 3rd March 2006 05:23 PM
Wago cage clamp sucks - or - the best connector in the world? peranders Parts 1 4th September 2003 09:20 PM
Copyright 1999-2017 diyAudio
