PP KT88, Need help! - Page 5 - diyAudio
Old 30th November 2012, 11:38 PM   #41
12E1 is offline 12E1  United Kingdom
12E1's Avatar
Originally Posted by EEApprentice View Post
I haven't been able to check anything when the feedback is connected for that channel. It is so loud I have to turn it off and I don't have a resistor box handy to load the output.
I wouldn't worry about a resistor box as such - many resistor boxes are not designed to handle significant power. I would find a pair of 8 ohm or similar wire-wound resistors rated to 25 or 50 watts. They can be ceramic, but I like using the aluminium clad ones since they can easily be bolted onto a more substantial piece of metal. Here's some.
Old 30th November 2012, 11:55 PM   #42
It does seem very possible that your left channel output transformer primary is wired in reverse compared to the right channel. That would give you positive feedback.
Right channel could be blocking distortion. http://www.aikenamps.com/BlockingDistortion.html
Old 1st December 2012, 06:49 PM   #43
Scott17 I will forever love you.
THE AMP IS FIXED! Not only that, it COMPLETELY exceeded my expectations. I cannot believe I've spent weeks and weeks trying to fix something that was just the primary of the left OPT wired in reverse. It was positive feedback all along!
I also added 1.7k grid stoppers to all my KT88s and replaced the capacitors for the fluttering channel.
THANK YOU EVERYONE! I was so disappointed when this thing didn't work but thanks to everyone throwing their ideas, it is finally fixed... And it sounds AMAZING.
Thank you again!
Old 1st December 2012, 06:54 PM   #44
DF96 is offline DF96  England
Getting the feedback phase wrong is a very common mistake in a new DIY amplifier. Occasionally the OPT secondary will be mislabelled. That is why we asked you to check it.
Old 1st December 2012, 09:17 PM   #45
I glad you've got it working and that you are happy. Fantastic.
I guess it's burned into you now to check that next time around.
kt88 PP rectifier. ruben alstad Tubes / Valves 7 5th September 2012 09:07 AM
Which KT88 PP and which Transformers? Dave S Tubes / Valves 66 8th January 2012 04:37 PM
Kt88 Pp barossi Tubes / Valves 2 24th December 2008 05:55 PM
KT88 PP suggestion jarthel Tubes / Valves 13 27th June 2007 02:10 AM
My new pp KT88 design baggystevo82 Tubes / Valves 41 16th May 2005 01:02 PM
Copyright 1999-2017 diyAudio
