Harmon Kardon A500
Harmon Kardon A500
Old 7th January 2013, 08:24 AM   #11
heespaul is offline heespaul  United States
Avincenty, thanks for reply. You are correct. I found and did a download. I am going to buy a Photofact and think about building a replica.I want to build one cuz i love, to say I could and to enjoy what I can't afford to buy. It is remarkably designed like the Madison Fielding 360 I am restoring. I will keep status posted. Cheers, Paul
Old 7th January 2013, 11:43 PM   #12
avincenty is online now avincenty  United States
I did build a quasi clone. Quasi because it doesn't have the phono stage, also it only has bass and treble control. From what i can remember, the a300,a500 and a700 are all similar, the output valve changes for more power. I built mine with jj7591 and Hammond 1650 transformers. It sounds very good. The one fault I find is a very slight hiss coming from the first gain stage when I place my ear close to my 99db sensitive speakers.
12ax7 gain stage to bandaxal tone to 12ax7 gain stage to 12au7 concertina to 7591a.
Alfredo
Old 8th January 2013, 01:03 AM   #13
Alfredo, I was looking over the photofact. You have my admiration for building this design. I am planning my first DIY amp. I am a novice so I am going to start with a kit. If nothing else it will insure I end up with a completed project. I am confident I could complete a project but do not have the equipment needed at the end. Speaking of 12AU7's, gain and hum, would a 5965 in place of a 12AU7 make sense due to it's lower gain. I have read allot of differant opinions on this tube. I have never read anyone comment in a before and after application. Have you substituted the 5965 for a 12AU7? I am curious to hear about them. Any thoughts?
Cheers, Paul
Old 8th January 2013, 02:39 AM   #14
My 12au7 is used in the concertina with unity gain irrespective of individual tube gain so i am not sure if it will make a sonic difference.
Afredo
Old 10th January 2013, 03:38 AM   #15
zoe is offline zoe  United States
I have rebuilt this amp.
be good
zoe
Old 10th January 2013, 03:50 AM   #16
This is the first amp that I've work on. Its been quite a evolution. I probably started seven years ago or so. Its still got the same 12AX7 driver tube and 12AU7 is still used
as the phase splitter but its a different kind its a cathode coupled splitter.I also now have a adjustable bias scheme with its own power supply so I can use different tubes.
be good
zoe
Old 10th January 2013, 03:54 AM   #17
pix
be good
zoe
Old 10th January 2013, 03:57 AM   #18
I have three of these now. I brought one to burning amp.
be good
zoe
Old 10th January 2013, 04:27 AM   #19
heespaul
Sherman audio has a lot of info.
be good
zoe
Harmon Kardon A500Hide this!Advertise here!
Harmon Kardon TS5 Sub mike49504 Car Audio 6 3rd February 2012 11:02 PM
Harmon Kardon TS5 Sub mike49504 Subwoofers 0 28th January 2012 05:26 PM
Harmon Kardon argonrepublic Solid State 2 23rd June 2009 07:30 AM
harmon kardon T-40 jaudio Analogue Source 0 24th October 2007 11:37 AM
Harmon/Kardon AVR35 nitryce Solid State 1 5th May 2004 02:22 PM
