Tank's DIY tube preamp - diyAudio
Old 10th November 2012, 07:05 AM   #1
Default Tank's DIY tube preamp
Hey guys.
a few weeks ago i posted here, questioning the quality of the ebay tube preamp kits.. and the results were mixed. after much contemplation i decided to give one of those kits a go after reading some good review about it - and im super happy i did so!!
This kit is a a super simple buffer tube preamp board with a 50k pot, and it also came with a transformer. the kit uses two 6n3 tubes, which were also suplied. after listening to it for a while i decided to give it a proper enclosure - and this is the result:
when i first approached this project, it was important for me to not just build a simple enclosure based on existing designs, but rather start from scratch on try to thing both on the looks but also on the manufacturing process - keeping it as simple as possible.
first of, i started with the three aluminum sheets. i marked everthing out, and made the first cuts in the board:
the next step was preparing all the wiring:
then i took things to my schools workshop for the building of the enclosure itself:
once all the holes were made, the wood was varnished and the welding began:
and once everything was hooked up:
at this point im 99 percent done, and other then a small shielding problem in the selector switch (which i will attend to shortly) everthing works great, and the sound is exactly what i was looking for when i first decided i want a tube preamp! bang for buck - this is one of the best deals i did in the audio world
so, what do you guys think? i did good? any suggestions for improvement?
Old 10th November 2012, 10:29 AM   #2
SY's Avatar
Well, you're listening to Joni during one of her better periods, so there's not much room for improvement.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 13th November 2012, 12:17 AM   #3
kevinkr's Avatar
Moved to Tubes / Valves on the premise that this thread would get more visibility here..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 13th November 2012, 10:57 AM   #4
freax's Avatar
great work man! What size brass standoffs are you using, M3 or M2?
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 13th November 2012, 02:31 PM   #5
i have no idea im assuming you are reffering to the little legs that hold the circuit to the board (and i may be wrong..) - i just used those i found in an old misc screws box my dad had i actually planned to change them because i want the board to sit higher up so the tubes will stick out more.
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
DIY Tube Preamp FBLEAGH Tubes / Valves 99 28th October 2012 08:51 PM
Diy Tube Phono Preamp alexmoose Tubes / Valves 39 11th December 2011 08:43 PM
Tube preamp diy kit Coilvoice Analog Line Level 3 12th July 2011 05:43 AM
DIY tube preamp with 5687 ervinl Tubes / Valves 18 4th May 2010 08:57 AM
Copyright 1999-2017 diyAudio
