Yaqin MS 34 D - Page 5 - diyAudio
Old 14th November 2012, 10:22 PM   #41
vinylkid58's Avatar
Originally Posted by bull041161 View Post
Will this tell me if i can run the amp on the uk voltage 240 as the amp only has a switch to run 220v. sorry for all the questions
Don't think so. Someone mentioned earlier in this thread about checking the heater voltage, to see if it measures high. You'll need to pop the bottom off to check this. Does the person coming over tomorrow have any experience working around high voltage sources?
jeff
Old 14th November 2012, 10:47 PM   #42
jeff
Hi he mends computers but knows nothing about valve amps or hifi. And i dont feel safe enough to do it my self. Wish there was someone close to do it for me i would happly pay as im desperate to hear what it sounds like
Old 14th November 2012, 11:31 PM   #43
Hi all well tried it for 10 mins with some crapy 60 watt gale speakers. It didnt sound bad to say it was not warmed up. Wanted to connect my fllor standers to it and turn it up. Would haveing it louder cause damage
Old 14th November 2012, 11:48 PM   #44
vinylkid58's Avatar
I would play it at moderate volume for a while, just to make sure it's working properly.
jeff
Old 15th November 2012, 12:20 AM   #45
jeff
Thanks for all the help and tips.I could not resist trying it just had it at what i call tv listening lol about quater of the way round for 10 mins. Then i relised when i had turned it of i didnt know which mode i had on triode ore the linier mode. When can i wind the volume up a bit after heater voltages have been cheked
Old 15th November 2012, 12:38 AM   #46
vinylkid58's Avatar
When can i wind the volume up a bit after heater voltages have been checked
I would give it a good hour, then if everything seems ok, you can crank it up a bit. You should get it checked out ASAP thou, to avoid any long term damage.
jeff
Old 15th November 2012, 12:50 AM   #47
jeff
Thanks again for the help. There is no nasty huming or distortion sounds clean. But the little speakers used for testing a rubish. Is it just the heater voltage i need to get cheked. Would have thought the manufacturers would have set the bias voltage wont thay
Old 15th November 2012, 01:03 AM   #48
vinylkid58's Avatar
Is it just the heater voltage i need to get checked.
It's the most obvious place to see if the amp is happy with your mains voltage.
Would have thought the manufacturers would have set the bias voltage won't they.
Maybe.
jeff
Old 15th November 2012, 01:18 AM   #49
Maybe.
jeff
Thanks alot i will get that cheked tommorow and report back. Do i have speakers connected amp on and volume turned down after warming the the valves up
Old 15th November 2012, 01:25 AM   #50
vinylkid58's Avatar
Yes.
YAQIN MS-22B. Any thoughts, please? vincula Tubes / Valves 13 6th February 2016 11:45 PM
Yaqin MS-20L tube recommendation cyto Tubes / Valves 4 25th April 2013 06:27 AM
Help - YAQIN MS-20L schematic pigeon_snake Tubes / Valves 4 11th January 2012 12:49 AM
Yaqin MS-12B output awkwardbydesign Analogue Source 0 13th November 2011 11:37 AM
Help - MS-6V6 Yaqin schematic wfmali Tubes / Valves 5 6th April 2010 07:55 PM
Copyright 1999-2017 diyAudio
