Yaqin MS 34 D - Page 3 - diyAudio
Old 12th November 2012, 12:22 PM   #21
Originally Posted by 12E1 View Post
Should be OK as a test load for the amplifier - but I would not use them for any listening testing since they will most likely have a limited frequency response (I am assuming that they are intended for use with a separate bass speaker).
Hi yes there just mid and trebble crappy things lol. My other speakers i will be useing for now are mission m74 till i have built my ipl tm line speakers
Old 12th November 2012, 12:26 PM   #22
12E1 is offline 12E1  United Kingdom
12E1's Avatar
OK - cool.
If needed - report back when you've been able to take the voltage readings.
Old 12th November 2012, 12:34 PM   #23
OK - cool.
Will do thanks again for the help. The amp as not arived yet thay say around 20th of this month. Just want to get ready for when it gets here lol
Old 12th November 2012, 02:41 PM   #24
This reminds me of myself when I ordered my first chinese amplifier. Don't have it anymore, I gave it away for free. I just hope you don't have the same kind of delay in the delivery and the customs trouble....
Old 12th November 2012, 02:49 PM   #25
It is anoying costis as im in the uk and it said the amplifier is located in london. So dont see why it should take up to 20 days. What amp was it. What made you get rid
Old 12th November 2012, 07:00 PM   #26
Somehow I doubt that somebody would stock in UK a product that is not certified for UK voltage. Maybe a gray import? Hmmmmm....
Well, the input sensitivity was too much, it was too crowded to modify, it was overheating (even though it was made for 230V), and the 6.3 VAC looked really nasty on the scope.
And above all, it was inferior to my self designed amplifier. So I gave it to my friend who came to audition my diy amp.
But then gain, I have to say that that little dingy thing was nearly indistinguishable with a well-regarded Italian tube amp that some other friend had at the time. Oh well, at least I didn't pay 2500 euros for that
Old 12th November 2012, 11:03 PM   #27
Hi costis i have a couple of amps one is the amp 6 basic from 41hz best amp i have had even better than the musical fidelity dr thomas pre and power amp. And the other is the hifimediy t50 100 watt amp this one is not so good and is never 100 watts rms
Old 13th November 2012, 10:43 AM   #28
Hi all the amp as arived. Cant wait to try it could some one please tell me what i should do before i connect my speakers. I have switched it on and every thing seems to be working
Old 13th November 2012, 01:57 PM   #29
Hi all is there anyone in sheffield area that could bias my amp as dont want to break it. I will pay for there time
Old 13th November 2012, 11:05 PM   #30
Can someone please help me out i want to try my amp but not sure if its its safe to do so. Do i have to set the bias on the tubes. Will it break the amp if i use it. I have switched it on for 10 mins with nothing connected and it seems fine
YAQIN MS-22B. Any thoughts, please? vincula Tubes / Valves 13 6th February 2016 11:45 PM
Yaqin MS-20L tube recommendation cyto Tubes / Valves 4 25th April 2013 06:27 AM
Help - YAQIN MS-20L schematic pigeon_snake Tubes / Valves 4 11th January 2012 12:49 AM
Yaqin MS-12B output awkwardbydesign Analogue Source 0 13th November 2011 11:37 AM
Help - MS-6V6 Yaqin schematic wfmali Tubes / Valves 5 6th April 2010 07:55 PM
Copyright 1999-2017 diyAudio
