Yaqin MS 34 D
Yaqin MS 34 D
Old 13th November 2012, 11:20 PM   #31
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
You should really have some speakers connected "before" turning on the amp. See if it will play music. Do you have a multimeter?
jeff
Old 13th November 2012, 11:29 PM   #32
bull041161 is offline bull041161  United Kingdom
jeff
Yes jeff i have multimeter
Old 13th November 2012, 11:48 PM   #33
vinylkid58's Avatar
Let the amp play some music for 20-30 minutes before you check the bias. There appears to be test points beside each output tube, and an adjustment port on the opposite side. You'll need a small screwdriver (slotted?) to turn the bias pot. With the mutlimeter set on millivolts, insert the probes into the proper test points. You should be getting something around 400 millivolts for each tube. Don't panic if the reading is a little higher or lower, we're assuming that there is a 10 ohm resistor on the cathode of each EL34.
Maybe just take readings for now and post them up here, before adjusting anything. Make sure the amp is not playing any music when you do this.
Don't forget, those big tubes are HOT!
jeff
Old 13th November 2012, 11:52 PM   #34
jeff
Thank you very much i will check voltages tommorow and post them
Old 14th November 2012, 12:02 AM   #35
vinylkid58's Avatar
Ok. I guess the amp didn't come with any documentation?
jeff
Old 14th November 2012, 12:03 AM   #36
rntlee is offline rntlee
There should be a torx screwdriver included with the amp to adjust bias with.
Old 14th November 2012, 12:12 AM   #37
jeff
Yes it comes with a user guid but tell you nothin. I t doesn t say any thing about tube bias just tells you what the controles are for, There is a torx driver and some spare fuses
Old 14th November 2012, 12:20 AM   #38
vinylkid58's Avatar
Well, at least you got a screwdriver.
jeff
Old 14th November 2012, 12:24 AM   #39
jeff
Yes and some spare fuses but its nice not too badly made and its heavy
Old 14th November 2012, 09:46 PM   #40
Hi all my meter is not working for some reason but i have someone comeing tommorow with another meter it says 1.4 v at side of the bias test points is this what i should get from the meter. Will this tell me if i can run the amp on the uk voltage 240 as the amp only has a switch to run 220v. sorry for all the questions
Yaqin MS 34 DHide this!Advertise here!
YAQIN MS-22B. Any thoughts, please? vincula Tubes / Valves 13 6th February 2016 11:45 PM
Yaqin MS-20L tube recommendation cyto Tubes / Valves 4 25th April 2013 06:27 AM
Help - YAQIN MS-20L schematic pigeon_snake Tubes / Valves 4 11th January 2012 12:49 AM
Yaqin MS-12B output awkwardbydesign Analogue Source 0 13th November 2011 11:37 AM
Help - MS-6V6 Yaqin schematic wfmali Tubes / Valves 5 6th April 2010 07:55 PM
