Suggestions for a cheap Stereo Phono tube preamp based upon this power transformer?
Old 5th November 2012, 12:32 AM   #1
freax is offline freax
freax's Avatar
Default Suggestions for a cheap Stereo Phono tube preamp based upon this power transformer?
[Pic of Transformer, use your imagination]
This has been sitting around the house for 7 years or more, after obtaining it from my beloved cousin.
Was wondering if anyone could point me in the right direction for a phono preamp based around this transformer?
The B+ mA rating is known as 100mA: Unknown mA on Gardners mains transformer
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 5th November 2012, 02:13 AM   #2
Eli Duttman is offline Eli Duttman  United States
Thankfully, this is an easy 1.
Build a tweaked RCA setup. I've attached the schematic.
Greinacher double, using Schottky diodes and BIG 'lytics, the 6.3 VAC and follow with a 7812 3 terminal regulator to get a good DC heater supply.
FWCT rectify the 300-0-300 taps, with 1200 PIV Schottky diodes. CRCRC filter the "raw" DC. The drops in the filter resistors are your "friend", in this situation. Use a pair of LR8 regulators to provide isolated 250 VDC to each channel.
Eli D.
Old 5th November 2012, 08:27 AM   #3
freax's Avatar
Sounds good to me, will start looking for some wood to prototype it on.
Could do with some help with the voltage doubler circuit. 2200uF values for the caps in the volt doubler circuit?
Just found this:
DC heating, parallel diodes
Whoa, 2x 10,000uF!?
Suggestions for a cheap Stereo Phono tube preamp based upon this power transformer?Hide this!Advertise here!
SSM-2015 based phono preamp ads2 Analogue Source 0 9th April 2012 12:20 PM
can I use this transformer to power the opamp based preamp? zome Parts 3 16th June 2009 11:27 PM
Transformer based phono stage biovizier Solid State 7 31st October 2005 09:12 PM
Cheap and Easy Tube Phono Preamp Kofi Annan Tubes / Valves 50 16th November 2004 12:37 AM
Copyright ©1999-2017 diyAudio
