Reference tube amp kit, <20 watts for under $1,000? - Page 4 - diyAudio
Old 22nd November 2012, 02:50 AM   #31
freax's Avatar
Yeah, I'll think about the OTL amp, thanks for your help guys.
Alright, I'll go with the OTL amp.
Removing those output transformers from the signal path is what convinced me that its a good idea regardless, that and the fact that I've currently got speakers that will sing just fine at 15 watts (Sony SS-212's), and that it consumes the same amount as an ST-70...
And that 10 watts tube power is enough for me, but 15 watts is even slightly better.
And I can always roll a couple of chip amps for the 12inch or 15 inch down throwing drivers.
Old 22nd November 2012, 03:15 AM   #32
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
What's the point of a nice amp with poor source and poor speakers? The amp makes the least amount of difference. You should upgrade the rest first and just use a chipamp for under $200.
When you have the funds, you can get a SE 845 or GM70 setup for your 20W of output. The transformers alone might cost $1000. An EL34 based amp is not going to be near as transparent as a direct-heated triode amp based on George Anderson's design.
Old 22nd November 2012, 03:34 AM   #33
freax's Avatar
I've got a nice source, its in the mail, arriving from Russia, then needs to be built.
nice, very nice: 6C33C OTL power amp running two heaters on OP tubes.. - YouTube
All I need now is good speakers.
Old 22nd November 2012, 03:35 AM   #34
You might be surprised what this OTL can do, but as cotdt mentioned, the amp is not nearly as significant as the speakers first and signal source second. Once they are taken care of, the right amp can bring it all to life.
Of course if you're in the mood for an amp project, then go for it. It would be hard to beat this OTL for the $$$.
I've been wiring like a maniac all night. Time for a break.
Old 22nd November 2012, 03:39 AM   #35
freax's Avatar
Indeed, its good to take a break once in a while from doing THAT many point to point joints.
You might be surprised what kind of amp I am using, a Sony STR-K670P
And I have reached the limit of what this amp can do, and I'm bored with it, infact its ticking me off.
It'll be a nice upgrade I reckon
I just hope I can get the order in before the country shuts down for the year...
Old 22nd November 2012, 04:14 AM   #36
Agreed, Freax. I've had one of these for a few years now (Sony STR-DA5600ES). It's actually great as a 7.1 processor, but for music listening, it's pretty much useless. Weak-kneed with a hard and thin sound. I can show you some $59 DACs from ebay that sound better than the one in this thing. The controls on the front panel are impossible to understand and the on-screen menus are just as bad. See that knob on the left marked "TONE"? Yeah, doesn't do what you'd expect - at all. And that's just the start...
Old 22nd November 2012, 04:20 AM   #37
freax's Avatar
Cheap tho, thats why I bought it, for $120 off ebay :P Mine does good as a bass driver, I might keep it hanging around to drive my 12 inch sealed sub in combination with the OTL tube amp.
OMG the dac is actually worse than my onboard soundcard's DAC!
This is the one that I'm working on at the moment: http://www.diyaudio.com/forums/digit...-off-ebay.html
I was surprised when I switched from using TOSLINK/optical SPDIF for 4 years over to analog rca just recently as an experiment.
I suppose back when it was made it was half decent for consumer gear, but not today, even when contending with an onboard motherboard DAC.. haha
Yep I had another Sony here with me not that long ago with Bass + Tone controls on it, neither one did a damn thing! Weak at the knees even for a cheap integrated chip amp.
Old 22nd November 2012, 09:35 AM   #38
freax's Avatar
Can you guys provide me a schematic? Info on this amp is eluding me.
I'm looking at their forum now.
Old 22nd November 2012, 12:41 PM   #39
Which amp? The 15W OTL? If so, the schematic is published in his book Tubes and Circuits: Bruce Rozenblit: 9781477532867: Amazon.com: Books and is copyrighted so I don't want to post it online.
From what I gather, this design is a fairly new upgraded circuit to his previous amps. It eliminates two transformers and a drive tube yet maintains all the OTL goodness.
He also has a 300B OTL monoblock project in there that is going to be a must build for me. The tubes aren't cheap, but the sound is supposed to be second to none. "The most glorious 1W in all of audio" is the claim. I have heard nothing to refute it. My long term plan is to biamp my Altecs and run the 15W OTL into the 15s and the 300Bs into the horns.
BTW, if you're ditching your Sony, what are you going to use for a preamp? I don't think a preamp is a must as it has an input sensitivity of 2.2V, but it is recommended.
Click around his website. Bruce has a refreshing DIY mindset and interesting philosophy with respect to audio. He also has an interesting DIY speaker project using full-range Tang Band 8" drivers. I built a pair for <$600 and they sound excellent for that $$$. 95dB sensitivity is very loud with 3W. They will work nicely with 1W and scream with 15.
Transcendent Sound DIY Specialist in Vacuum Tube OTL Amplifiers
Old 22nd November 2012, 01:54 PM   #40
freax's Avatar
Bugger, oh well I'll just have to use my imagination and your build pictures for now :P
I've wanted to build a 300B amp for almost a decade, enjoy
Yes I saw that this afternoon, for now I will do without and just power it with whatever the TDA1543 can muster, I've thought about swapping out the driver tube(s) with something with a bit more gain, I would like to try the 12AU7 but it hasn't got more gain than the 12AT7...If it becomes an issue I might get a really high quality 12AX7... or something with a gain of 90 instead of 60 (12AT7).
I'll have to use my turntable preamp if things get too desperate, I'm not going to build a tube preamp just yet :P I might be able to fit a battery tube preamp into the TDA1543 DAC which /might/ put out 2.2v pp but it would be a super tight squeeze.
I'm outta luck until I can get a preamp and will just have to make do.
This is what the DAC puts out:
Analog first output
The output voltage of 0.7 M RMS when connecting a digital signal corresponding to 0 dB
The first output OR1/OL1 is for connecting to a tube amp that has high input impedance, 300k Ohms - 500k Ohms and sensitivity of 300 mV.
XP3
Pin 6: Out R1
Pin 5: Common bus, GND
Pin 4: Out L1
Analog second output
The second output OR2/OL2 is for an upgrade. You can connect Up Transformer through a capacitor 10 uF. For example Sowter 4383 or equivalent. In this case, you can use an amplifier with an input impedance of 47k ohms and a sensitivity of 1V.
XP3
Pin 3: Out R2
Pin 2: Common bus (GND)
Pin 1: Out L2
http://www.ebay.com.au/itm/130681589933?ssPageName=STRK:MEWNX:IT&_trksid=p398 4.m1497.l2649
No good for me, I'm not in the mood to be cutting wood up, I've got my eye on the Frugel Horn flat pack kits: SOUND WITH STYLE - CUSTOM LOUDSPEAKERS Frugel Horn MK3 kit flat pack Mark Audio Fostex Tang Band
20 Watts Car Stereo Amp with TDA2004 EronSilva Solid State 3 20th February 2010 05:31 PM
10 000 watts from Sweden - Labgruppen peranders Solid State 63 23rd April 2009 06:24 PM
Please: tube kit for <$300? EmergencyDpt Tubes / Valves 9 22nd August 2008 12:17 AM
Opamp with open loop gain of 1,000,000,000,000,000. :-P Circlotron Solid State 9 26th June 2003 11:32 AM
Copyright 1999-2017 diyAudio
