MC Step-Up OTL Stage (grounded-grid) for MM RIAA Head Amps - diyAudio
Old 1st November 2012, 08:44 PM   #1
tiefbassuebertr's Avatar
Default MC Step-Up OTL Stage (grounded-grid) for MM RIAA Head Amps
about
Teflon coupling capacitors & More No-Gain—No-Pain Tube Buffer Circuits
I have found such examples.
I want to know commercial RIAA phono preamps where such topologies are in use.
Thank you for advices.
Old 2nd November 2012, 01:12 AM   #2
The amount of capacitance needed at the I/P is HUGE, in order to obtain good bass performance. Both physical size and monetary outlay are prohibitively expensive, if PTFE dielectric is to be employed.
If you want to do LOMC phono, without a step up trafo (SUT), investigate Allen Wright's hybrid cascode.
Eli D.
Old 2nd November 2012, 09:07 AM   #3
the right electrolytic capacitors in signal pad (biased condition) is no audible disadvantage, so I think (additional - dc coupling is dangerous for moving coil cartridges).
Check out MLGO+ about
http://www.mundorf.com/english%201.1/kondensatoren2.htm
Ultrasimple mm/mc RIAA preamp 2 Mad_K Analogue Source 340 28th June 2016 09:26 PM
Ultrasimple MM/MC RIAA Preamp mkIII GlidingDutchman Analogue Source 5 2nd July 2008 07:42 PM
ls-37 MM/MC RIAA Phono Amp from diyclub.biz wuffer Tubes / Valves 2 13th November 2004 04:12 PM
ultrasimple mm/mc riaa preamp Mad_K Analogue Source 109 31st July 2004 06:34 PM
Copyright 1999-2017 diyAudio
