diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Mighty Midget Amplifier and speaker requirements. (http://www.diyaudio.com/forums/tubes-valves/222371-mighty-midget-amplifier-speaker-requirements.html)
Fivetide 28th October 2012 01:21 AM
I’m really very new to DIY audio, and have been building up project by project; I have built a CMOY and an O2 headphone amp. I decided for my next project to build a simple valve amp, and reading Pmillitt’s article on the mighty midget thought that would be a great noobie amp to make. So I have now almost everything except the Edcor transformers, which I have ordered and hopefully will receive soon
The thing is I have realised it has an output of “With a B+ voltage of about 300V, the amp puts out about 3.5W per channel, while dissipating under 10W on the plates of the output tubes. THD at 1W into 8 ohms is about 0.7%. “ Now I have a pair of bookshelf kef q1’s “Amplifier Requirements: 15-120W” I know this is a silly question but will I need to buy some more speakers that only need 3.5W PC to drive them ?
jerluwoo 28th October 2012 03:04 AM
Your Q1's are a little low in sensitivity at 91db but should be fine if you dont need it loud.
Fivetide 28th October 2012 10:43 AM
Originally Posted by jerluwoo (http://www.diyaudio.com/forums/tubes-valves/222371-mighty-midget-amplifier-speaker-requirements-post3217966.html#post3217966)
Thanks for that, I dont play loud music :)
Resources saved on this page: MySQL 18.75%
