6sn7 driving Push Pull Parallel kt88's?
Old 27th October 2012, 11:47 AM   #1
ruben alstad is offline ruben alstad  Norway
Default 6sn7 driving Push Pull Parallel kt88's?
Does the 6sn7 have guts to drive a quad of kt88s in push pull parallel.
in a Williamson configuration that is.
id assume so since the 12au7 drives kt88s in normal P-P in many circuits,
and the 6sn7 seems to be alot like it but just bigger and more linear.
any suggestions?
Old 27th October 2012, 12:00 PM   #2
bigspeaker is offline bigspeaker  Australia
any suggestions?
the 6sn7 should be what you call the phase split inverter its what drive the output tubes there shoud a be a 2nd 6sn7 driving the first 6sn7 the gain or guts comes from the pre driving into the 2nd 6sn7 witch then drives the 1st 6sn7 the phase tube its what we call drive/phase/output the 6sn7 is the big daddy to the 12ax7 i have added data sheets
abd some circuts to give you a idear
Old 27th October 2012, 12:08 PM   #3
so i take it two 6sn7s one for gain and one for phase driving 4 kt88s is viable.
i thought the 6sn7 was more like the 12au7 because of gain factor.
Old 27th October 2012, 12:19 PM   #4
12ax7 will be better 12au7 to low if you are using it for guitar amp i buit such a amp with 12ax7 and it worked very well
Old 27th October 2012, 12:22 PM   #5
thought guitar amplifiers ect was for another forum.
Old 27th October 2012, 12:25 PM   #6
12ax7 will work fine 3 12ax7 and your kt88's it will rock you have circuit
Old 27th October 2012, 12:27 PM   #7
the circuit were to give an idea of how all the bit fit
Old 27th October 2012, 01:00 PM   #8
trying to pull off an octal tube only amplifier, a 6sn7 driver phase kt88 PPP stereo amplifier has being floating on my mind alot recently.
Old 27th October 2012, 08:28 PM   #9
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
Don't believe everything you read, even here. The 6SN7 is an excellent driver, even in the extreme case of triode connected output valves.
All good fortune,
Chris
Old 28th October 2012, 08:34 AM   #10
multi is offline multi  Australia
GEC developed a circuit for Multiple Kt 88 using 6SN7's. The amp uses a 6SN7 cathode follower to drive the out put stage for low impedance drive.
The last tube you would want to use to drive KT88's or 6550's is a 12AX7 they are hi mu high plate resistance, high distortion tubes and no good as drivers, nothing like a 6SN7 which is low mu, low plate resistance, low distortion and excellent driver.
Can scan the circuit if any one interested but it is on the Net
Phil
6sn7 driving Push Pull Parallel kt88's?Hide this!Advertise here!
Chinese amp: 2A3 6SN7 6SJ7 5Z5P push pull Alexontherocks Tubes / Valves 16 7th May 2013 04:37 AM
Push-Pull vs Push-Pull-Parallel rsumperl Tubes / Valves 8 10th July 2012 05:34 PM
VTV Push-Pull 6SN7/KT88 Amp: DIY or China? 88man Tubes / Valves 5 18th October 2009 02:27 PM
driving 845 push-pull with a signal from a 300B SE stage Antonio Tucci Tubes / Valves 1 20th February 2007 08:04 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
