Filter capacitors - motor run?
Old 25th October 2012, 09:06 AM   #1
Aner is offline Aner
Question Filter capacitors - motor run?
I am planning to build a WE91 clone based on 300b. I saw some designs that have used oil filled motor-run capacitors for filtering. Is this a good practice? In general what is the recommended capacitor type for filtering?
Thanks,
Aner
Old 25th October 2012, 10:45 AM   #2
andyjevans is offline andyjevans  United Kingdom
Motor run caps are polypropylene. Also often called "film caps". They can be oil filled or not. They come in various qualities, but in general ALL polypropylene caps sound better than all electrolytic caps. If you have room use all polypropylene caps in your PSU. They are bigger, and if you don't have room, the final capacitor in the chain, e.g. CLC, should be polypropylene. I believe this sums up good practice as usually expressed in these forums. No doubt others will advise in more detail.
Old 25th October 2012, 05:23 PM   #3
kevinkr's Avatar
The motor runs work great, my preference is for oil filled ASC and GE types. Do not confuse these with motor start capacitors which are generally much more compact and contain short lived electrolytic caps not intended for continuous duty.
Preferably purchase ones that have a DC voltage rating in addition to the AC operating voltage. Generally you are safe running them at up to DC values equivalent to the Vpk value represented by the stated rms value.. In many cases the safe DC voltage may be a lot higher than this, but unless disclosed this would be the safest way to go.
In tube amp supplies operated conservatively they will probably outlast you..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 26th October 2012, 05:36 PM   #4
Cassiel is offline Cassiel  Libya
Me testing a non electrolytic amp. Sounds softer (not happy about this) but it might be because it's tube rectified. The original is not. Too soon to say but starting to think not worth the additional space.
Old 26th October 2012, 05:59 PM   #5
Davec113 is offline Davec113  United States
Davec113's Avatar
Try the Clarity Cap TC series or Mundorf M Tube Caps in the power supply, huge upgrade over electrolytics, even bypassed...
Old 26th October 2012, 09:02 PM   #6
indianajo is offline indianajo  United States
indianajo's Avatar
I used two Genteq 97f5211 50 uf 440 VAC film caps, to replace 47 uf 450 VDC rated electrolytic caps in my organ. I have two 5AR4 tube rectifiers. It can be run really loud, particularly the bass. The caps show a 1000 VDC rating stamped on them. Huge, I put them in a separated chassis connected to the original by twinax 18ga cable. Ground shielded one end, plus up and back in the same cable, minus up and back in the other cable. I have 40 ohm chokes (original) between the rectifiers and the caps, 47 ohm 5 watt resistors (not stock) between the transformer and the plates. The load is a pair of 7591 tubes on bass and two pairs of 6BQ5 tubes for the treble, and 17 other tubes for signal processing.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 22nd December 2012, 06:16 PM   #7
misok is offline misok
now i'm a bit confused, i need another 100uf cap, and i have to choose between JJ electrolytic and a big polypropylene motor-run. same price cca 11eur. what to do ? thanks
Old 22nd December 2012, 07:26 PM   #8
If you have room, use all motor runs. If you are tight for space make the last cap motor run.
Old 22nd December 2012, 10:43 PM   #9
A capacitor rated 440v AC should be OK for 1.4 x that figure in DC, in other words around 600v.
Old 22nd December 2012, 10:48 PM   #10
thank you. ( i deleted my post before i saw you reply, because i found out i was wrong in that calculation)
ok, so im going happily for those big white chunks. at least i'll feel more serious!
Filter capacitors - motor run?Hide this!Advertise here!
Motor run caps? albireo13 Tubelab 12 5th March 2010 08:35 AM
Motor run caps as power supply filter coldcathode Parts 27 16th October 2009 07:13 PM
motor run caps grahamb Parts 3 17th September 2009 11:14 PM
motor run capacitor milen007 Parts 12 28th June 2008 05:49 PM
Motor Run Capacitor Zap Parts 2 14th May 2008 09:59 PM
