Filter capacitors - motor run?
Old 24th December 2012, 03:41 PM   #21
Triodethom is offline Triodethom  United States
Triodethom's Avatar
Originally Posted by jcx View Post
its continuous DC bias at higher V that stresses dielectric
if "toughness" is just surviving seconds of transients then its no indication
Higher DC fields drive different degradation/breakdown phenomena to penetrate a dielectric over time - opto isolator WVDC ratings are lots lower than the 1, 60 sec withstand test V because of this
I'm suspicious that maybe the datasheet writers are just doing the AC Vpk math - and may have never tested at 1000s of hrs with DC bias
Ok but I do'nt see the opto isolator correlation to polyprop motor caps. Please go on . As for the 1000s of hours of test would years of use over the rating suffice or is there some other lab rating that will do ? The stress of dc bias and resulting failure is not to be taken lightly some examples of such would help there should be from the manufactures web sites. Regards
Old 24th December 2012, 04:37 PM   #22
indianajo is offline indianajo  United States
indianajo's Avatar
"Motor caps" rated at a certain AC voltage must withstand shutoff transients of 6 to 10 times running voltage. That is what motors put out if not transient suppressed. If you put a scope in a factory AC line, that is what you will see. So that sort of explains why film motor caps are so huge. I imagine the 1000 VDC rating of my 500 VAC genilec caps in my organ is very conservative. I don't expect to ever replace them, not at the current a 5AR can deliver to them. Heat is one thing that really kllls plastic film. Won't get much of that in hifi service, unless the mounting postition is wrong.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Filter capacitors - motor run?Hide this!Advertise here!
Motor run caps? albireo13 Tubelab 12 5th March 2010 08:35 AM
Motor run caps as power supply filter coldcathode Parts 27 16th October 2009 07:13 PM
motor run caps grahamb Parts 3 17th September 2009 11:14 PM
motor run capacitor milen007 Parts 12 28th June 2008 05:49 PM
Motor Run Capacitor Zap Parts 2 14th May 2008 09:59 PM
