Filter capacitors - motor run? - Page 2 - diyAudio
Old 22nd December 2012, 10:52 PM   #11
Pano is offline Pano  United States
Pano's Avatar
And that's important!
Old 22nd December 2012, 11:29 PM   #12
jcx is online now jcx  United States
I see that DC = AC peak Vrating in the datasheets - not certain how strongly to believe - it turns out blocking high DC V is much harder on a real world dielectric over time vs AC - and these AC motor run caps really aren't expected to see appreciable DC for their entire working life
Old 22nd December 2012, 11:38 PM   #13
I'd just passed on what I understood - that DC is 1.4 x AC. I'm no expert on these things, and do please make any corrections needed!
Old 22nd December 2012, 11:39 PM   #14
Pano's Avatar
yeah, i've always wondered about that.
Old 23rd December 2012, 09:00 PM   #15
Chris Hornbeck's Avatar
I've used 660VAC rated *used* motor run caps at 1170VDC for many years. They even survived an incident of soaring to about 2KV for a short period. But I do keep 'em inside the chassis. Not really recommended, but a data point.
All good fortune,
Chris
Old 23rd December 2012, 09:22 PM   #16
Triodethom's Avatar
That a bit over the 924 dc rating. Sounds like the rating is on the modest side of a rating .
Old 23rd December 2012, 11:16 PM   #17
Motor run, especially for 660VAC caps, is probably fairly hard work, in series for motor current, start-stop spikiness, etc. I don't know about "audiophile credentials" but they're plenty rugged.
Thanks,
Chris
Old 24th December 2012, 12:08 AM   #18
its continuous DC bias at higher V that stresses dielectric
if "toughness" is just surviving seconds of transients then its no indication
Higher DC fields drive different degradation/breakdown phenomena to penetrate a dielectric over time - opto isolator WVDC ratings are lots lower than the 1, 60 sec withstand test V because of this
I'm suspicious that maybe the datasheet writers are just doing the AC Vpk math - and may have never tested at 1000s of hrs with DC bias
Old 24th December 2012, 01:04 AM   #19
12B4A is offline 12B4A  United States
12B4A's Avatar
What kinds of failures have been reported using motor run caps in DC operation?
Old 24th December 2012, 01:06 AM   #20
JoshK is offline JoshK  Canada
Originally Posted by andyjevans View Post
A capacitor rated 440v AC should be OK for 1.4 x that figure in DC, in other words around 600v.
I've seen that rule of thumb as well and given their original intention it seems *fair* but maybe not always relied on.
Motor run caps? albireo13 Tubelab 12 5th March 2010 08:35 AM
Motor run caps as power supply filter coldcathode Parts 27 16th October 2009 07:13 PM
motor run caps grahamb Parts 3 17th September 2009 11:14 PM
motor run capacitor milen007 Parts 12 28th June 2008 05:49 PM
Motor Run Capacitor Zap Parts 2 14th May 2008 09:59 PM
Copyright 1999-2017 diyAudio
