Helllo,
i'm currently going to build my first Engineer's Amplifier using the standard setup.
If it works well (more, if i don't make a mess), i'll need another one for rear speakers. That's quite not an issue.
But i'm planning on going from 4.0 to 5.0 or 5.1 system and for the central speaker i would love to get the same setup as the Engineer's Amplifier but in Mono, is it possible to do it? Is it easy? Would it be possible to "cut" the PCB to get it smaller? --> ok i'm stopping quesions now
Speakers will be Davis Stentaure LE for front (LE C for central) & Clint for back.
Sound source will be proivided by the Asus Xonar D2X. (I might had another source from my room from the opamp modded Xonar Essence STX, to see the difference)
Thanks!
Thanks!
